CD Changer Alpine
Old Sep 5, 2002 | 01:35 PM
bejane's Avatar
Default CD Changer Alpine
Hey are there FM Modulated and NON FM Modulated versions of the same Alpine CD Changer model numbers?
For example: If someone has a Alpine CHM-s601 and had a FM Modulator, would this Changer work with my 91 Legend stock unit without the FM Modulator?
I now know I can plug up a Alpine CHM- S601, 620, ect. but the FM Modulated thing threw me for another loop <*grin*>
Thanks. Billy.
Old Sep 5, 2002 | 02:31 PM
GSRaCeRbOI's Avatar
Default Re: CD Changer Alpine (bejane)
can't you just buy that $30 honda to alpine adapter and connect the CHM-S01 or 620 via the DIN cable and forget about the whole FM Modulater unit?
audioroach's Avatar
Yes billy...it will work...the changer just plugs into the modulator...so if you have access to a fm modulator version...you can use it by eliminating the mod part.
You need the adaptor to make it work properly ( there are a few pinsthat are reversed in the setup...the adaptor corrects it)
[Modified by audioroach, 5:34 PM 9/5/2002]
Old Sep 6, 2002 | 07:35 PM
DB5000's Avatar
Old Sep 7, 2002 | 04:41 PM
philly-O's Avatar
Default Re: CD Changer Alpine (DB5000)
i have one of those adaptors if you are interested. i will sell it for $20 shipped.
Old Sep 10, 2002 | 12:34 AM
killerprelude86's Avatar
i wounder y he keeps doing that but still have 0 post????? anyone
Old Sep 10, 2002 | 12:45 PM
HandCommand's Avatar
If your factory Honda/Acura head unit has CD changer capability, I highly recommend using a cable interface that was mentioned to connect to your Alpine CD Changer.
Not only are you able to utilize the CD functions straight from the factory head unit, but the CD sound quality will not be limited to the FM receiver section of your stock radio. A direct connect will always be better than going through the FM radio using a FM modulator.
Old Sep 11, 2002 | 08:30 AM
Toby1's Avatar
Default Re: CD Changer Alpine (HandCommand)
If you're so inclined you can make the modification to the Alpine cd cable yourself. You'll just have to switch two pins in the cd cable's DIN plug. I did it myself in less than 5 minutes, and it saved me $20-$30. If you know how to solder then you should try it.
Here's the URL for that mod:
http://integra.cyberglobe.net/caraud...grams/DIN.html
HTH!
pityocamptes
Dec 3, 2012 03:39 AM
PlayaKSavztheDay
Audio / Security / Video
Oct 17, 2009 07:27 PM
clark kent
Feb 28, 2003 10:38 AM
girlRacer
Nov 11, 2002 06:39 AM
