capaciters??
Old Jul 22, 2004 | 09:18 AM
ackerjack's Avatar
Default capaciters??
i just bought a 1 farad capacitor and i wasnt sure how to hook it up could anyone help me out?
Old Jul 22, 2004 | 09:39 AM
hybridzOr's Avatar
Default Re: capaciters?? (ackerjack)
take your power wire, put it to positive of the cap, run another wire from the positive on the cap to either your amp or dist. block.
then ground the cap. and take another wire, from the neg. terminal then run that to the amp or dist. block
did you "pre charge" the cap yet?
Old Jul 22, 2004 | 11:58 AM
nsxxtreme's Avatar
You want the capacitor as close to the input of the amplifier as possible, with the wires being as short as possible as well.
Old Jul 23, 2004 | 10:15 PM
ackerjack's Avatar
Default Re: capaciters?? (Hybrid Racer.)
thats actually more at what i was asking about the precharging part what do i have to do to do that part of it i know it involves hooking it up directly to the battery with a bulb attached to it. thanks
Old Jul 24, 2004 | 04:40 AM
Xsi's Avatar
Xsi
Connect the ground to a ground, connect a bulb in between the positive lead and the capacitor, when the bulb goes dim the cap is charged. Instead of the bulb some caps come with a charging resistor.
Old Jul 24, 2004 | 07:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Connect the ground to a ground, connect a bulb in between the positive lead and the capacitor, when the bulb goes dim the cap is charged. Instead of the bulb some caps come with a charging resistor.</TD></TR></TABLE> 94
patrick4588
Audio / Security / Video
26
Jun 17, 2008 08:10 AM
Blahblah718293
Mar 25, 2008 07:15 AM
thatasiankidtony
11
Apr 5, 2007 01:53 PM
R Thizzel
17
Nov 22, 2004 05:48 PM
ChronicFrogs2004
10
Aug 2, 2004 02:53 PM
