cannot find a good ground
Old Jul 5, 2003 | 03:52 PM
basshead's Avatar
Default cannot find a good ground
chassis is rotten, what do i do? ground to the batery? should i put the battery in the trunk with the amps so the wire is shorter? the chassis has holes in it all over the place and it is currently being welded, should i weld a ground wire in there somewhere?thanks, jomo
Old Jul 5, 2003 | 04:04 PM
vteg's Avatar
New User
Default Re: cannot find a good ground (newbster)
Find a place that is not rusted out. Sand down to the metal, and put a hole for the ground screw.
Old Jul 5, 2003 | 11:09 PM
nsxxtreme's Avatar
Do not put the battery in the trunk unless you like toxic fumes or you have a sealed battery.
doh
Just read it was JOMO never mind put a lead acid battery in the trunk and get high of the fumes. J/K
Old Jul 5, 2003 | 11:27 PM
PetroGuyX's Avatar
take a flathead screwdriver and take the coating off the trunk, then you should have a good ground to the chassis
9818tegr
Apr 2, 2009 09:38 PM
nello a.
Aug 23, 2007 12:16 PM
Mr. Giggles
Jul 8, 2006 07:40 AM
hatchinprogress
10
Jun 8, 2006 08:46 PM
crxh22project
Mar 14, 2005 04:52 PM
