can i do this...
Old May 23, 2005 | 10:12 PM
idriveadelsol7's Avatar
Default can i do this...
Eclipse SW8122DVC this speaker runs at 4ohms (dual voice coil). can i run it at 1 or 2 ohm? i have a mono block 1000rms at 1 ohm but 400 at 4 ohms which is way to underpowered for this thing.
Modified by idriveadelsol7 at 11:48 PM 5/23/2005
Old May 24, 2005 | 06:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: can i do this... (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">Eclipse SW8122DVC this speaker runs at 4ohms (dual voice coil). can i run it at 1 or 2 ohm? i have a mono block 1000rms at 1 ohm but 400 at 4 ohms which is way to underpowered for this thing.
Modified by idriveadelsol7 at 11:48 PM 5/23/2005</TD></TR></TABLE>I don't see the sub on their site, http://www.eclipse-web.com so I assume it's an older one, but if it's a DVC 4ohm, you can wire the VCs in parallel so you get a 2ohm load, the amp should work with a 2ohm load. 94
Old May 24, 2005 | 06:49 PM
Default Re: can i do this... (fcm)
cools...that's what i needed. my amplifier runs 400@4 ohms and 600@2 ohms and that sub requires 500. thanks
Old May 24, 2005 | 10:32 PM
zumiez007's Avatar
Old May 25, 2005 | 05:02 AM
TeenyTymer69er's Avatar
Default Re: can i do this... (zumiez007)
well i have 2 powerbase subs there 4 ohm, i can wire them at 2 ohm?
Old May 25, 2005 | 05:17 AM
fcm's Avatar
fcm
Old Fart
Default Re: can i do this... (TeenyTymer69er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeenyTymer69er &raquo;</TD></TR><TR><TD CLASS="quote">well i have 2 powerbase subs there 4 ohm, i can wire them at 2 ohm?</TD></TR></TABLE> Yes, wire the subs in parallel, the same way you wire a DVC sub, it's just that the VCs are on 2 subs 94
Old May 25, 2005 | 07:32 AM
nsxxtreme's Avatar
To figure out parallel impedence
1/(1/impedence1+1/impedence2+1/impedence3 + 1/ect......)
lickety_britches
Audio / Security / Video
Dec 18, 2007 02:46 PM
xBlackMikex
Apr 18, 2007 05:59 AM
Gouki133
Nov 28, 2006 04:08 AM
Audio28
Sep 11, 2006 07:36 AM
brickonwheels
Mar 12, 2004 08:50 PM
