buzzing through the speakers....
Old Sep 15, 2002 | 09:14 AM
Ham'ed Hatch
Guest
Posts: n/a
Default buzzing through the speakers....
alright well i had some problems hooking my amp up a while ago some of you may remember...
well it was working great untill yesterday. i get in the car turn it on, and now there's this constant high pitched buzz when the stereo's off (and on i'm sure, just can't hear it over the music). it's relative to my motor, when it revs, the buzz gets slightly louder.
also, when i switch the amp's crossover, i hear a *click* through the speaker. never did that before...
when i routed my wires, i made sure none of them were near my car's wire harness, so what else could cause this and how can i fix it?
Old Sep 15, 2002 | 09:21 AM
Jadis's Avatar
Default Re: buzzing through the speakers.... (two.oh)
This happened to my friend he said something about his ground was messed up, so you might want to check out your ground and see if it's alright
Old Sep 15, 2002 | 09:59 AM
b18bEG's Avatar
Default Re: buzzing through the speakers.... (Jadis)
usually its when you had you stereo installed, all teh wires were runnig down the same side. that wil cause engine noise. always the speaker wire, and the ground remote wire should be on seperate sides..
Old Sep 15, 2002 | 05:18 PM
b20guy's Avatar
Default Re: buzzing through the speakers.... (h22akrd)
Also try this, with regards to the ground for your amp. Remove the ground, use a sander, dremel, or whatever, and remove any painted area the ground screw, bolt might tough to the chassis, then reinstall your ground.
Old Sep 15, 2002 | 05:53 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: buzzing through the speakers.... (b20guy)
it's getting worse, it's sooooooooooooooooooooooooo annoying!
i'll try the ground tomarrow...
Old Sep 15, 2002 | 07:20 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
your prolly running your power wire next to your rca's. either run the power wire far away, or buy some high quality rca's (monster, rockford)
Old Sep 16, 2002 | 07:41 AM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: buzzing through the speakers.... (BoroDB8)
i'm using a Honda cd player.
my amp has high level imputs or whatever they're called.
InvaderTrax
Audio / Security / Video
11
Jan 15, 2007 08:02 PM
rockin_remz
May 27, 2006 07:30 PM
ebp_dc2
16
Mar 25, 2005 12:30 PM
Accord1959
Dec 3, 2004 07:14 AM
pbcdb
Feb 25, 2004 05:14 AM
