Battery disconnection?
Old Jan 19, 2004 | 09:31 AM
Hehehe I just's Avatar
Default Battery disconnection?
Hey guys,
do i have to disconnect my battery before installing a headunit in my 93 accord. if i do do i disconnect the negative terminal first or the positive terminal? quick reply needed. thanks.
Old Jan 19, 2004 | 09:39 AM
MassMayhem's Avatar
Default Re: Battery disconnection? (Hehehe I just)
No need to disconnect battery, unless you are borderline spastic and don't trust yourself around live wires. Use a wiring harness, good connectors, and the right crimpers and you're in.
Old Jan 19, 2004 | 09:54 AM
Default Re: Battery disconnection? (MassMayhem)
actually i was going to solder and not crimp. is that ok?
Old Jan 19, 2004 | 10:09 AM
pbcdb's Avatar
Crimping is easier imo. But there is no need to disconnect the battery as long as you dont touch the 12v power wire to anything metal. If you did happen to touch it to something it will just blow the fuse anyway. To disconnect the battery just take the negative terminal off.
Old Jan 19, 2004 | 10:31 AM
MassMayhem's Avatar
Default Re: (pbcdb)
solder w/ heatshrink or nice crimps (Aamp makes good stuff-if it's good enough for NASA it's good enough for me!). Either one will do fine. Good luck.
Old Jan 19, 2004 | 10:45 AM
GAtegs's Avatar
I would disconnect it just incase. Better sfe than sorry, you know?
Old Jan 20, 2004 | 06:17 PM
snoochtodanooch's Avatar
Default Re: Battery disconnection? (a98tegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a98tegLS &raquo;</TD></TR><TR><TD CLASS="quote">I would disconnect it just incase. Better sfe than sorry, you know?</TD></TR></TABLE> agreed, but sometime i am lazy too.
Old Jan 20, 2004 | 06:33 PM
Default Re: Battery disconnection? (snoochtodanooch)
i eneded up not disconnecting it. i feared it might blew up in my face, that happenned to my friend. instead i just plugged it in. soldered the wires and then wrapped them in electrical tape. it looks good. next weekend i will ground it to the chasis. right now it is just on a piece of metal aboce the ash tray.
Old Jan 21, 2004 | 07:25 AM
rcurley55's Avatar
New User
The first step to any installation is to disconnect the battery!!
Usually, when you don't, a thread follows the next day with a title along the lines of:
"Help, my dash lights don't work"
or something of that nature. Unless you absolutely need it connected, I always recommend you disconnect it. It can save you some hassles down the line.
fleabag
Jul 2, 2012 09:39 AM
tyronne1126
Jun 15, 2008 02:07 PM
crxh22project
19
Mar 23, 2005 08:19 AM
ubreak_ubuy
Audio / Security / Video
Jul 19, 2004 02:37 PM
