basic audio help
i have a 99 ex and ima put the 1st amps and subs ever in it lol. but have a few questions before anything.
1. When u plug the battery wire from amp to battery why do u need the fuse, wat happends if u dont, and can u use the wires that have the fuse but there not the tube fuses..
2. remote wire: this goes in back of ur deck harnest or cars harnest. i have 1 solid blue wire, and blue with white stripes.
3. wats an easy way to hide the wires without taking out the seats.
Thank you everone thats helps ^.^, i know its noob but i need to learn some how ^^
The fuse on the amps power cable is to protect the power cable and in so doing, protect the car from burning to the ground.
A shorted out amp power lead that is not fused will get red hot instantly, burn off the insulation, and ignite anything combustible around it.
You should use an ANL fuse... http://www.scosche.com/products/sfID.../productID/781 of the proper amperage for the power cable gauge you are using.
Amp control lead, [remote wire] should be connected to the HUs, [deck] harness, blue/white lead, [the blue lead is for power antenna].
You should remove at least the pass. seat and you will have to remove the rear seat if amp is not being mounted under the pass. seat, the amps RCA leads should be run down the center of the car, the amps power lead should be run on same side of car as the batt., [mostly on the pass. side] and once carpet is moved away from rocker panels, [door sill] it will be easy to see how to run the power cable. 94
your fuse should be attached as close to your battery as possible so if it blows you dont hurt anything else. it should also say on the bottum of back of the deck should tell you want color the remote wire is as far as i know i believe its the blue and white wire that u attach ur solid blue wire back to your amp.An easy way to hide your wire is go underneath your vechicle or you could also take of the side panels and stick tightly and nicely in there but make sure you done have the power wire and rca cables wired on the same side it can cause static in the amp and makes the sub hummmm split it up on each side of the car with rca and remote wire and then power wire on the other side.. hope this helps
wilaivue
Audio / Security / Video
Jun 4, 2010 04:57 AM
90civic_tio
May 23, 2005 06:55 AM
