Audiobahn Sub wiring problem. Please help!
Old Apr 24, 2005 | 09:03 AM
Buck99Si's Avatar
Default Audiobahn Sub wiring problem. Please help!
Well, I bought this dual coil 10 inch AW1000Q, and there are two positives and two negative terminals on each side or coil of the sub. I don't know how the hell to wire it to get a four ohm load or two ohm. I really just want four ohm. Every configuration I've tried has made my amp cut off or go into overload. Can somebody shed some light on this thing for me please? When I say two of each on each coil I mean two positives side by side, then two negatives side by side. This is on either side of the basket. Thanks!!
Old Apr 24, 2005 | 09:54 AM
fcm's Avatar
fcm
Old Fart
Default Re: Audiobahn Sub wiring problem. Please help! (Buck99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buck99Si &raquo;</TD></TR><TR><TD CLASS="quote">Well, I bought this dual coil 10 inch AW1000Q, and there are two positives and two negative terminals on each side or coil of the sub. I don't know how the hell to wire it to get a four ohm load or two ohm. I really just want four ohm. Every configuration I've tried has made my amp cut off or go into overload. Can somebody shed some light on this thing for me please? When I say two of each on each coil I mean two positives side by side, then two negatives side by side. This is on either side of the basket. Thanks!!</TD></TR></TABLE> What is the imp. of the VCs. The two term. on each + and - is just to make it easy to connect the wires, treat them as one, also need to know what kind of amp, [make and model] and I could not find an AW1000Q sub at http://www.audiobahn.com is it an older one? 94
Old Apr 24, 2005 | 10:15 AM
cd5_2NR's Avatar
Default Re: Audiobahn Sub wiring problem. Please help! (fcm)
it probably is an older model..i have the A1200Qs...
do a search..i think rockford fosg. has a site that shows how to wire down ohms...there are plenty of "how to's" on dvc wiring...
Old Apr 24, 2005 | 10:24 AM
Buck99Si's Avatar
Default Re: Audiobahn Sub wiring problem. Please help! (cd_5TUNR)
Okay, thanks everybody! I searched and found a helpful page on Crutchfields website concerning subwoofer wiring. It's really useful. Now I just need to test the impedence of this thing.
Old Apr 24, 2005 | 07:58 PM
canis's Avatar
man you should of seen my face when i was trying to wire up MY AWES12P's now that was a few years ago... damn that sucked..... but i got it hooked up and now... damn i think personaly its one of the nices subs out there... 3 years and going guys....
Old Apr 26, 2005 | 01:20 PM
bigapple427's Avatar
Default Re: (canis)
you should wire the series parelell you series the sub and par.. at the amp. its real easy.
lickety_britches
Audio / Security / Video
Dec 18, 2007 02:46 PM
89hbcivicguy
Jun 18, 2007 05:09 PM
8point6
16
Apr 21, 2005 11:50 AM
Traction
Dec 24, 2003 11:21 AM
teq1816
Sep 12, 2001 10:47 PM
