audio problems
Old Nov 2, 2004 | 09:46 AM
jdmintegraDC2's Avatar
Default audio problems
Hi, I have a question and I would like to ask for your opinion and suggestion. I recently bought 2 12' alpine type r subs 300watts RMS each (1000watts max each). I connected to a 1000 watts max. Koiiler amp. I use 400watts max speaker wires. Ever since i hook the two up, my car battery have been dying. Before i bought the systems, my battery was fine. Now every 1-2 months, i have to recharge my battery. Could it be that my wires doesnt have enough power to handle my speakers, so its using my battery for assistance. I was just wondering if it because my system is too powerful for my amp and its using my car battery to help it or what?...i need advice...anything would help...thanks!
Old Nov 2, 2004 | 10:57 AM
02AccordBigBoi's Avatar
Default Re: audio problems (jdmintegraDC2)
I say get a capacitor and if that doesnt work go for a yellow top to power your system, or maybe your current battery needs replacing, you know they die after a while and recharging them only helps in the shortrun.
Old Nov 2, 2004 | 12:26 PM
selasornayr's Avatar
Default Re: audio problems (02AccordBigBoi)
Do not get a capacitor until you have addressed these things...
1. Upgrade your "Big 3" wires, which are the battery positive to the alternator positive, alternator to chassis ground, and negative battery to chassis ground. Most aftermarket grounding kits come with 8ga wire, and many people say that it's enough, but then again, those are the same people who don't run crazy electronics. Upgrade those wires to 4ga. Oh yeah, while you're at it, you might as well upgrade your other grounds... do a honda-tech search for "grounding kits."
2. If you still have a problem, upgrade your alternator to a high output one. Chances are that your alternator isn't recharging your battery fast enough, which is why your battery is draining all the time.
3. Change your battery to a deep cycle/starter battery. I have the Yellow Top Optima, and it can be drained to nothing and charge back up fully up to 300 or so times.
Looking at your setup, go through those things, and you should be fine because you're not running a massive system (I am.... muahahahaha). Theoretically, if you go through these 3 things, and you still have problems (like with dimming), then a cap would help.
Old Nov 2, 2004 | 02:16 PM
nsxxtreme's Avatar
If your battery is dying like that then you need an upgraded alternator.
Or your battery is dead as already mentioned
Old Nov 3, 2004 | 12:43 PM
Default Re: audio problems (selasornayr)
what brand is ur battery?...Could it be that my wires are not strong enough for the subs....I only have those skinny 300watts wire i bought from wal-mart...Do u recommend me getting the 1400watts wire?
Old Nov 3, 2004 | 01:11 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmintegraDC2 &raquo;</TD></TR><TR><TD CLASS="quote">what brand is ur battery?...Could it be that my wires are not strong enough for the subs....I only have those skinny 300watts wire i bought from wal-mart...Do u recommend me getting the 1400watts wire?
if you're wires were too skinny they'd melt. simple as that. what gauge is the wire you have now?
i'd say change the battery first, if that doesnt fix it check the alternator.
Old Nov 4, 2004 | 08:11 AM
Default Re: audio problems (EBP_SI)
i just got a brand new battery. My alternator is like 2 months old. I dont know wat guage wires im using
Old Nov 4, 2004 | 08:30 PM
Clifton Santiago's Avatar
hey bro what mods have you done to your car? any chance you have an aftermarket alt. pulley? i had the same problems you are having, cause i didn't put the stock one back in after i had system installed.
Old Nov 5, 2004 | 10:54 AM
Default Re: audio problems (Clifton Santiago)
no i dont have any aftermarker alternator or pulley....sorry bro.
Old Nov 12, 2004 | 08:43 AM
zerphyte's Avatar
Batterys are *not* maitence free, I don't care what anyone says. Before you do ANYTHING, check the water in your battery.. It might be low, could be. If you don't know how to check it, PM me.
Old Nov 14, 2004 | 10:39 AM
zumiez007's Avatar
Default Re: audio problems (zerphyte)
The wire would not make your battery die. Get some atleast 10ga speaker wire from the amp to the subs. Go to a stereo shop or home depot. Stay away from walmart.
Old Nov 14, 2004 | 02:06 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerphyte &raquo;</TD></TR><TR><TD CLASS="quote">Batterys are *not* maitence free, I don't care what anyone says. Before you do ANYTHING, check the water in your battery.. It might be low, could be. If you don't know how to check it, PM me.</TD></TR></TABLE>
REALLY, lets see you check the acid level in a optima battery. Or how about a stinger dry cell. All adding water does is dillute the acid. Your better of replacing the missing acid.
ezza
Mar 4, 2009 05:37 PM
nyzd79
Mar 14, 2008 09:20 AM
jdmintegraDC2
Nov 3, 2004 12:45 PM
jdmintegraDC2
Nov 3, 2004 12:43 PM
