AUDIO HELP!!!! INTEGRA DA 91
i just bought a 91 DA n i tried hooking up my radio to it... every time i turn the volume up the music starts to crackle... its not ther radio because i used it b4.. in the fuse box 4 acc. there is a 20 amp fuse ..should it be higher, lower or is it the right size fuse..i need help!!!
Sounds like ypu have a shorted speaker or wire. Easiest way to find it is to disconnect all speaker wires, start reconnecting them one at a time with the deck playing at moderate a level. When you find the speaker/wire that starts distorting the output signal, start to check wires/connections at that speaker.
Kirk R
Kirk R
Steven P
May 7, 2016 02:36 AM
byronl
Audio / Security / Video
Jun 22, 2005 08:16 AM
