Any compustar folks on here?
Old Sep 19, 2020 | 04:16 PM
nsxxtreme's Avatar
Default Any compustar folks on here?
I used to be more active on this forum many years ago. I purchased 2 compustar CM3000M alarms many years ago from a dealer that frequented this forum. I installed one of those alarms in a vehicle I had at the time and never had an issue with it. The other sat in the box until just yesterday. My fathers vehicle was stolen a few days ago and he just recovered it. I had an extra alarm just sitting in a box so I told him I would install it.
I took it out of the box and decided to bench test it before installing. I hooked up the main harness. Connected the red wire straight to the battery, red with white stripe straight to the battery, Green wire straight to the battery, black wire straight to the negative terminal. I plugged in the antenna, led, shock sensor, pager antenna and I was expecting it to do something........ I got nothing out of it. Toggled the remotes and still nothing. Is this thing dead or am I missing something? Fuses are all good.
If its dead any of you able to get it warrantied? Thanks in advance!
Old Sep 20, 2020 | 09:05 PM
nsxxtreme's Avatar
Default Re: Any compustar folks on here?
Figured out my problem the remotes come unprogrammed from the factory. Man its crickets in here. This place used to be way more active.
Cjkelley87
Sep 5, 2012 03:19 PM
MantisX
Audio / Security / Video
10
Sep 1, 2009 11:11 AM
theeogflip
May 5, 2008 09:45 PM
pKjai
Apr 7, 2008 03:20 AM
candyman206
Feb 7, 2008 06:24 AM
