amplifier problem need help asap...
Old May 26, 2003 | 05:40 PM
BlueSi2k's Avatar
Default amplifier problem need help asap...
hey, im hooking up my brothers system and his amp is giving +6.xx volts from both the ground and remote terminals on the amplifier. the led goes on when the power is hooked up even without the ground and remote hookup up. as soon as the power wire touches the power terminal the led goes on whether anything else is hooked up or not. any ideas? thanks
Old May 26, 2003 | 05:57 PM
t0p_sh0tta's Avatar
Default Re: amplifier problem need help asap... (BlueSi2k)
Does everything else work properly? Will it play music? Make any funky noises? I think something may be shorted out internally, but I have no clue.
Old May 26, 2003 | 06:01 PM
BlueSi2k's Avatar
Default Re: amplifier problem need help asap... (t0p_sh0tta)
nope wont power the subs and no noises. I think its either internally in the amp or somewhere in the power wire. The wire is kind of old maybe ill try changing it. Thanks
Old May 26, 2003 | 08:41 PM
BlueSi2k's Avatar
wow im a retard...whipped out the voltmeter and saw i had a bad ground...
teggy182
Audio / Security / Video
Mar 21, 2008 06:25 PM
DynastyRacer22
11
Mar 31, 2006 05:09 PM
ZexyAccord
27
Dec 14, 2004 08:12 PM
clutch33
May 28, 2004 07:33 AM
mattduskater
May 12, 2003 04:49 PM
