AMP And Volt Question
Old Feb 2, 2006 | 08:27 PM
ChirpinSecond's Avatar
Default AMP And Volt Question
I have a 95 ex and have 2 rockford amps in it... i have a duralast gold battery that has been in there for a year... ive noticed that the car runs at 14 volts while driving but while stoped it goes to 12.6 volts.... the car also seems like it almost wants to cut off... i really need some advice on what i need to do... i have a rockford 1 farat cap but dont know if thats enough... its prolly 1200 watts combined with the two amps.... should i get a different alternator... anyone??
Old Feb 3, 2006 | 04:06 AM
B18C_EJ8's Avatar
Get a load test done on your alternator. Most parts stores will do the test for free...
Old Feb 3, 2006 | 09:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: AMP And Volt Question (ChirpinSecond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Get a load test done on your alternator. Most parts stores will do the test for free... </TD></TR></TABLE>Ditto the above. also what is the models of the 2 RF amps? and when you say "almost wants to cut off" I assume you mean stall, and is that when you have the audio system on? 94
Old Feb 4, 2006 | 04:43 AM
Default Re: AMP And Volt Question (fcm)
Yes the car wants to stall per say.... im not too sure what models they are im presuming they are a bit older... maybe the model from 3 years ago.... also it reads 14.3 volts usually and after the car is on for a bit i get a reading of 12.6 volts.... thats a big thought.... i took it to an audio store and they reccomended to change/upgrade alternator OR to get a bigger cap... they guy was leaning on getting a new/upgraded alternator though... any ideas???
Old Feb 4, 2006 | 08:57 AM
fcm's Avatar
fcm
Old Fart
Definitely go to a batt./alt. shop and have it checked out, what concerns me is the drop in voltage from 14.3V to 12.6V once car is warmed up, it sounds to me like once the alt./ voltage regulator heat up the output from the alt. is cut, 12.6V is what I would expect to get off a fully charged batt. when the motor is not running.
Try this, disconnect the amps power, [pull fuse] warm the car up till voltage drops to 12.6V then disconnect the batt., [pull the neg. term.] let me know what happens. 94
Old Feb 6, 2006 | 04:50 AM
ill try this tonight... and i will let you know what happen... thanks for the advice!
Old Feb 8, 2006 | 07:53 PM
i figured out the problem... thanks for the help man!!!
Old Feb 9, 2006 | 04:11 AM
B18C_EJ8's Avatar
And the problem was???
Old Feb 9, 2006 | 09:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">And the problem was???</TD></TR></TABLE>Ditto that, I could have sworn he said he would let us know.
Old Feb 9, 2006 | 05:07 PM
TurboLaxx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChirpinSecond &raquo;</TD></TR><TR><TD CLASS="quote"> ive noticed that the car runs at 14 volts while driving but while stoped it goes to 12.6 volts</TD></TR></TABLE>
Yes this is what honda's do. I have a digital volt meter hooked up to my car and at stoplights it runs about 12.6 votls and while driving it's about 14.5 volts. My car never feels like it wants to stall at 12.6 votls. I dont even have to be running my stereo for it to drop down to 12.6. It's what the car does. I wish all these so called "audio guru's" would know **** like that and not tell you to get your car fixed.
Old Feb 10, 2006 | 04:26 PM
fcm's Avatar
fcm
Old Fart
Default Re: AMP And Volt Question (TurboLaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLaxx &raquo;</TD></TR><TR><TD CLASS="quote"> I wish all these so called "audio guru's" would know **** like that and not tell you to get your car fixed.</TD></TR></TABLE> Do you know what I wish, That all the "johnny come latelies" would actually read the posts, because then they would see, first, the reason he was asking was, unlike your car, his was almost stalling, and second, no one here told him to fix anything, only how to go about getting something checked for free, and third, he found the problem, and I assume fixed it. 94
Kusai.Nihonjin.Desu
Jan 1, 2005 08:41 AM
shhh151
Audio / Security / Video
10
Apr 30, 2004 10:21 AM
Synergy001
Jun 12, 2003 03:01 PM
dannyboi
12
Jan 7, 2003 10:32 PM
