Amp throwing an error....
Old Oct 2, 2005 | 09:15 AM
B18Sleeper's Avatar
Default Amp throwing an error....
Ok I posted that my there was a problem with my amp...it wasnt pushing power to the subs. Ok I fixed that problem. Now my amp worked for about 10 minutes then threw a E-3 code on my LCD display screen. What is wrong and how can i fix it? Its a mrd m500 alpine thanks
Old Oct 2, 2005 | 10:16 AM
B18Sleeper's Avatar
Default Re: Amp throwing an error.... (RedlineKustomz)
Ok Ifound out what E-3 is its excessive current. How do I fix that? I got hte code ot go away a few times but it still pops up like 5 minutes later. Whats the problem?
Old Oct 2, 2005 | 10:44 AM
fcm's Avatar
fcm
Old Fart
Again go to http://www.alpine.com click on Support FAQ and then on speakers and amps, or contact us, customer sevice is 1 800 421 2284 94
Old Oct 2, 2005 | 10:58 AM
B18Sleeper's Avatar
Default Re: Amp throwing an error.... (fcm)
Well thanks again for the same website. I mean trully I hate calling companies cause you get the run around and it takes you hours to fix the problem when it could take minutes. Which is why I am asking you all but seems like no one can help. Thanks alot tho
Old Oct 2, 2005 | 03:01 PM
fcm's Avatar
fcm
Old Fart
How do you have the subs wired what is the final load, [impedance]? Alpine amps are not stable below 2 ohms, and depending on what Type R subs you have DVC 2 ohm or DVC 4 ohm and how they are wired parallel or series or a combination of both, if they are all paralleled you would have a 1 ohm load on the DVC 4 ohms a .5 ohm load on the DVC 2 ohms , so how they are wired may be a problem 94
Old Oct 2, 2005 | 06:25 PM
B18Sleeper's Avatar
the subs i got are the SWR-1221D whichever that is. I have them wired as so....you have a postive and negative on each side, i have the + wire from my amp goin to one sides + then the - goes to the other sides negative with a wire connect the other sides - with the last + if that makes sense.
Old Oct 2, 2005 | 07:08 PM
B18Sleeper's Avatar
is this right or wrong? but the thing about it is that it still throws the code even when I dont have the subs hooked to the amp... could it be my headunit?
Old Oct 3, 2005 | 07:32 AM
B18Sleeper's Avatar
Old Oct 3, 2005 | 07:41 AM
B18C_EJ8's Avatar
If it's giving you a code when the subs aren't hooked up, then you may very well have an internal problem with the amp.
Call tech support.
Old Oct 3, 2005 | 10:09 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">If it's giving you a code when the subs aren't hooked up, then you may very well have an internal problem with the amp.
Call tech support. </TD></TR></TABLE>I agree, it sounds like a problem in the amp, or possibly the "input level" (1-2) is not set properly? It has to be set between 0.5 -8.5V for the MRD-M500 94
Old Oct 3, 2005 | 10:34 AM
B18Sleeper's Avatar
Default Re: (fcm)
I have it set on 0.5
Old Oct 3, 2005 | 11:06 AM
B18C_EJ8's Avatar
Well, since 0.5 is within the acceptable limits of the input voltage range, I say, again, that it sounds like a problem with the amplifier's internals...
Call tech support.
Old Oct 3, 2005 | 11:18 AM
B18Sleeper's Avatar
I will call tech support. Thanks anyways
hookedonvtec
Audio / Security / Video
13
Jul 7, 2004 06:41 AM
MikeHock
Mar 30, 2004 05:10 PM
ErikDaGenErik
Nov 20, 2003 05:10 AM
joek84
Sep 29, 2003 05:17 PM
