Which amp is suitable for this sub?
Old Mar 22, 2004 | 08:13 PM
Norcalstoppy's Avatar
Default Which amp is suitable for this sub?
I'm finally thinking of getting a little bass for my car. I'm looking at a drive with the following spec:
-Recommended Amplifier Power: 100-400 Watts.
-Continuous RMS Power Rating: 400 Watts.
-Depth: 6 1/2 inches (7 1/2 inches is needed for mounting because the vented back plate requires "breathing room").
-Recommended Sealed Box Dimensions: .5 to 1.6 cu.ft.. The lower the size of the box, the greater amplification needed. For the flattest frequency response in car applications, do not use a ported box design.
-Impedance: 4 Ohms.
-Ship-weight: 17 lbs.
Which amp is the best value for the money? I want something that's decent in performance and most importantly, something that is reliable and solid.
Thanks.
Jay Kim
Old Mar 22, 2004 | 08:15 PM
rcurley55's Avatar
New User
so what kind of sub is it - tell us the brand and model number
also, what kind of box will you use
and what's your budget
Old Mar 23, 2004 | 11:27 AM
GAtegs's Avatar
Default Re: Which amp is suitable for this sub? (Allmotormonsters)
Is it a single voicecoil? JL AUdio 500/1.
Old Mar 26, 2004 | 10:16 AM
sopiwnykg's Avatar
Boston Acoustic Amps are the greatest things out there right now. I have two running my system right now and it exceeded my expectations. I've owned Phoenix Gold amps, Coustic, Pioneer, and final picked up my boston amps. I would say look into those. They have a bunch of different sized 2 channel amps available.
http://www.bostonacoustics.com...ID=19
Old Mar 26, 2004 | 12:31 PM
spark plugs.
Guest
Posts: n/a
if you want reliabilty, durability, and it's tried and true...get an alpine. don't skimp on the money if you want good sound.
Old Mar 27, 2004 | 02:19 PM
It's from Hsu Research and their only car subwoofer, ASW1203.
I'll be using sealed enclosure, probably Q-logic with 1.25 cu.ft.
This is the link:
http://www.hsustore.com/asw1203.html
Jay Kim
cpl rampage
Audio / Security / Video
10
Jun 22, 2009 04:58 AM
Hanmin
Jun 3, 2009 10:36 PM
A R M E N .
Apr 3, 2006 05:31 AM
marcus27
Jan 30, 2005 11:43 AM
Hasboro
Dec 20, 2003 10:49 AM
