Amp question
Old Jul 13, 2003 | 03:40 PM
Nader_D's Avatar
Default Amp question
I have a brand new a1 channel amp and i have 2 10" subs, i had the two sub wires connected to each other (+ and +, - and -) then from there i had the wires from the subs to the amp, it worked fine, everything was good, i unplugged everything, to organized it all, when i plugged everythinb back in, it didnt work. what can i try?
Old Jul 13, 2003 | 03:45 PM
Xsi's Avatar
Xsi
So the subs are DVC? how many ohms per voice coil? you may be running your amp too hard
Old Jul 13, 2003 | 03:54 PM
Nader_D's Avatar
Default Re: (Xsi)
does tha tmean that i blew my amp? im gonna look up in the manual and see what they say about bridging the **** together, we'll see
thanks
Old Jul 13, 2003 | 04:36 PM
PetroGuyX's Avatar
you might wanna try + to - and + to - and run it parrallel
Old Jul 13, 2003 | 06:46 PM
warrick's Avatar
sounds like you had it in parallel..
___+(sub1)-___+(sub2)-_____
|________+(amp)-__________|
will be in series... if the subs are 4ohm single voice coil, you'll be running 8ohms, which is probably too high. if they're dvc, run the 2ohms each (on the sub itself, + to +, - to -) and then as pictured above, that will run at 4ohms and will almost definitely run with the amp. otherwise, if the amp will run at 1ohm, run the subs at 2ohms each, and then in parallel again (+ to + between subs). if it will run 2ohms, run the subs at 4ohms (+ to - each sub itself) and then in parallel to the amp...
I'll shut up now.
Old Jul 14, 2003 | 06:47 PM
Nader_D's Avatar
Default Re: (warric_k)
well guys, figured it out, damn im stupid, connected a + and - together then decided to plug it in, BYE BYE FUSE, hahah thats what it was , what would yyou recommend for a fuse? thanks
Old Jul 14, 2003 | 08:35 PM
Xsi's Avatar
Xsi
A fuse of the same value, never bigger
Old Jul 14, 2003 | 08:58 PM
Torridcivic's Avatar
Default Re: (Xsi)
Warric_k knows his stuff
good man
redDAinteg
Audio / Security / Video
10
Apr 28, 2009 06:38 PM
ctownintegra
Oct 29, 2004 07:57 PM
h22accordr
Jun 6, 2004 12:02 AM
brickonwheels
Feb 1, 2004 09:44 AM
Drum_Guru
Oct 8, 2003 08:22 PM
