AMP problem, 2 speakers not working....
Old Feb 16, 2006 | 07:12 AM
Tonyl507's Avatar
Default AMP problem, 2 speakers not working....
I dont know TOO much about car audio, but here goes....
I bought a integra with 2 additianl 6x9's mounted in the trunk, they are powered by a 4-channel amp. The amp is wired to power the additnal 6x9's, and also the stock 6 1/2'' in the back seat. Problem is the speakers in the backseat ("channel A") aren't working. The 6x9's (Channel B) do work. Not sure if the amp is busted, or not set right or what... any ideas on how to get all 4 rear speakers working?
Did a search, but cant find any solid solutions...anyone got any ideas?
Old Feb 16, 2006 | 07:16 AM
Tonyl507's Avatar
Default Re: AMP problem, 2 speakers not working.... (Tonyl507)
set up is:
pioneer Deh-p3500 headunit
amp - pioneer "class A" GM-X904 (old amp im guessing, cant find info on it...)
rear 6x9's = Pioneer 4-way
Rear 61/2 = Pioneer 2 way
Pioneer componets in the front doors also...
Old Feb 16, 2006 | 08:06 AM
anewbreedx008x's Avatar
amp's fried dude, i work at circuit city install
Old Feb 16, 2006 | 08:17 AM
suspendedHatch's Avatar
Default Re: AMP problem, 2 speakers not working.... (anewbreedx008x)
Get a 9 volt battery and "pop" the speakers from the wiring at the amp.
I also work at CC and wouldn't make a guess like that without trying a couple of things. In fact I diagnosed a truck that had an old system done by us and it turned out that the LF speaker quit working because one of the speaker wires wasn't soldered, just wrapped and taped. The initial guess by the salesman that helped him was that the amp was fried.
Old Feb 16, 2006 | 12:09 PM
Tonyl507's Avatar
Thanks, yeah i thought the amp was dead...
I hooked with all 4 speakers onto one channel for now and it seems to work pretty good like that, is there any danger in keeping it like this until I get soem cash to buy a new amp??
also, all 4 speakers do work fine
Thanks again
Old Feb 16, 2006 | 05:11 PM
LSRracing95's Avatar
yeah, there is danger in doing that because the impedance will not be what is recommended for each speaker.
do yourself a favor, ditch ALL the rear speakers.. and either put the 6 1/2s in the front doors or get new 6.5s and put them in the front doors accompanied by a sub.
Old Feb 27, 2006 | 03:26 PM
Tonyl507's Avatar
Default Re: AMP problem, 2 speakers not working.... (LSRracing95)
UPDATE: well I got another 4 channel amp (my friends) that works in his car, and SAME problem, the one channel (A) doesn't work.....
So I pulled out the H/U.... switched the RCA plugs (put channel A into B and B into A), and bamm, the B channel donsnt work.
Which leads me to belive that the one side of my RCA outputs on my headunit are not working....am I correct? any way to fix this? or new headunit?
Old Feb 27, 2006 | 03:32 PM
Tonyl507's Avatar
OR, can I use the single RCA side that does work and buy Y-splitters for it??? anyone?
Old Feb 27, 2006 | 10:50 PM
Znypar's Avatar
sounds like a bad RCA cable to me.
(A) wont work, then you swap, now (B) wont work. one of those wires must be dead.
if so, replace it
Old Feb 28, 2006 | 06:41 AM
Tonyl507's Avatar
Default Re: (Znypar)
thanks, ill try it
Chefduncan
Audio / Security / Video
23
Dec 27, 2009 07:34 PM
Cody2289
14
Feb 11, 2008 09:28 AM
Rubixcu7
Oct 28, 2005 09:16 AM
Torridcivic
Sep 23, 2003 07:49 PM
