rsx cluster in ef hatch problems!
Old Nov 19, 2010 | 11:05 AM
88 EF Hatch's Avatar
Default rsx cluster in ef hatch problems!
so I installed an rsx cluster in my 88 hatch (b16a swapped), and everything works fine except for the tach. The tachometer works, but whenever i get close to redline (8200) the tach needle goes berserk, it also does it when i am using 2-step before a launch. I also have an autometer tachomether, and that one works perfectly fine, so I don't know if its something that is wrong with the tach, or wiring or if all you rsx ppl have the same problem with your 2step. help
88 EF Hatch
Nov 19, 2010 11:28 AM
swirve1
May 25, 2009 08:03 PM
