fuses keep blowin...
Old Sep 20, 2002 | 05:04 PM
NA EJ1's Avatar
Default fuses keep blowin...
im hookin up an amp and everytime i go to hook the power up to it, it blows the 2 fuse on the amp...i have everything hooked up besides the negative side of the battery...as soon as i hook it up it blows the fuses...any ideas why? thanks in advance..
[Modified by CC94B18, 9:05 PM 9/20/2002]
Old Sep 20, 2002 | 08:04 PM
NA EJ1's Avatar
Default Re: fuses keep blowin... (EVIL Teken)
so what do you suggest i do to fix it?
Old Sep 20, 2002 | 08:39 PM
kwhitelaw's Avatar
Default Re: fuses keep blowin... (CC94B18)
Verify you don't have a short on your wire running from the battery to the amp. Completely remove the wire and lay it outside of the car or on top of the carpet. Try it then. If it still blows the fuse while the key is out of the ignition you probably have a bad amp. If it blows a fuse with the key in, check your remote wire for the same problem. Something may have been pinched under a panel or where the wire runs under the back seat.
Steven P
May 7, 2016 02:36 AM
civiccoupe94
Sep 19, 2008 01:27 PM
Skeletor
Audio / Security / Video
Sep 6, 2007 09:50 AM
Ronin Integra8
Jun 3, 2003 05:18 PM
Understeer
Aug 23, 2002 03:04 PM
