Amp is not coming on, please help.
Old Jun 12, 2003 | 09:47 PM
Civic Type-R's Avatar
Default Amp is not coming on, please help.
Couple days ago I hit a bump and my amps went out, finally got time to check it out today, find out that the groud wire was lose, so I reconnected the ground wire, but my amp still not coming on, I checked all the wire and they seems ok. One thing I noticed is that when the ground wire was lose, the amp automatically draw power from the RCA cable, is that normal?? Can someone please tell me where to look to help my amp come back on.
thanks
Old Jun 12, 2003 | 11:42 PM
vteg's Avatar
New User
Default Re: Amp is not coming on, please help. (Civic Type-R)
Check all the connections again. And fuses.
If you cannot find it a voltmeter can make the job easier.
Old Jun 12, 2003 | 11:44 PM
Ludeboi's Avatar
same as above, and also check your ground...is it grounded well? is it touchin bare metal? if not sand it down a bit.
Old Jun 12, 2003 | 11:56 PM
Default Re: Amp is not coming on, please help. (Ludeboi)
I've checked everything already, all the fuse and all the connection. I'll go ahead and sand the grounding surface again tomorrow will see. Is is normal that if I put the ground out, and the RCA cable will act as a source of power?? Because that's what happen, I put the ground out, and the amp went on.
Thanks
Old Jun 13, 2003 | 04:07 AM
Xsi's Avatar
Xsi
Definately check the ground, if it fell off in the first place then it's probably not good.
The RCA cable may act as a ground if it's grounded, not a good thing to do for your amp
Old Jun 13, 2003 | 07:44 AM
PetroGuyX's Avatar
Default Re: Amp is not coming on, please help. (vteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">Check all the connections again. And fuses.
If you cannot find it a voltmeter can make the job easier.</TD></TR></TABLE>
make sure rca's are still plugged in, remote lead is still hooked up, all that good stuff, and definatly check the fuses
Old Jun 13, 2003 | 12:19 PM
Default Re: Amp is not coming on, please help. (PetroGuyX)
Found the source of the problem, it is the remote wire, got it fixed. Thanks a lot guys.
bug b16b
Acura TSX
Mar 19, 2012 08:43 PM
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
sma_V6
Nov 19, 2006 07:15 PM
xoutlawz00x
11
Dec 15, 2004 01:24 PM
2K GSR
Jan 15, 2004 08:17 PM
