amp keeps going on and off
my amp keeps on going on and off. it makes noise to the speakers.. im only powering the 2 front speakers.. do you guys know why its going on and off and making weird noises??? is it maybe because my power cable is too small?? could that be the problem???
maybe it's overheating and shutting off. where is the amp located and what kind of amp is it? does it only happen when you turn up your music loud or on a hot day... be more specific
loose remote turn-on??
loose power line??
loose ground??
power too close to rcas/speaker will make noise not turn the amp on/off
also give us FULL specs of what ur running...
Head Make&Model
Amp M&M
Wire sizes, power/ground/speaker
rcas: custom or off-the-shelf
to do ur own diagonistics.. get a digital mulitmeter to test all ur wires :-)
they run u about 20 bucks for a decent one that does the job well.. 10bucks will get you a POS...
unless ur lucky and sears have their $20 DMM on sale for 10.99.. but that was a few months ago...
loose power line??
loose ground??
Head Make&Model
Amp M&M
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman »</TD></TR><TR><TD CLASS="quote">What size is your power cable? Also check your grounds as well as the other connections.
its pretty damm small maybe its that.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx »</TD></TR><TR><TD CLASS="quote">maybe it's overheating and shutting off. where is the amp located and what kind of amp is it? does it only happen when you turn up your music loud or on a hot day... be more specific</TD></TR></TABLE>
umm it a 300 watt amp. it was working a while ago. then i started up my car to go somewhere and it wasnt working right. it kept on going on and off.. you couldnt really hear the music cause of the amp going on and off.. its under the passanger side[QUOTE=bpr0422]loose remote turn-on??
i checked the ground and grounded somewhere different. and i reconnected the power and remote turn on and it was still doing the problem...
loose power line??
loose power line??
ws350z
Audio / Security / Video
Sep 21, 2008 07:59 PM
