amp installation
Old Sep 11, 2004 | 05:03 PM
btran's Avatar
Default amp installation
Hello all,
I want to install an amp&sub in my 98 civic coupe. I install amp& sub before but not on a civic. What is the easiest/best way to run the power cable/RCA to the trunk ?
Thanks,
T
Old Sep 11, 2004 | 07:40 PM
drkblue_civic's Avatar
Default Re: amp installation (btran)
take the power cable in through a grommet right above/around the steering column and route it under your kick panels.....then take the rca's down the passenger side kicks panels....thats how i did it
Old Sep 11, 2004 | 08:32 PM
swatdog's Avatar
i hear u should sepearate your RCA's and power cables... does it relaly make a difference? i got lazy and put everything together
Old Sep 11, 2004 | 08:47 PM
fcm's Avatar
fcm
Old Fart
Default Re: (swatdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swatdog &raquo;</TD></TR><TR><TD CLASS="quote">i hear u should sepearate your RCA's and power cables... does it relaly make a difference? i got lazy and put everything together</TD></TR></TABLE> You can get noise if you run them together, it is less of a problem when its for a sub amp, but it still can be so bad that you won't like it. 94
Old Sep 11, 2004 | 11:15 PM
lotas's Avatar
easiest to just do it right the first time, then you dont have to worry about popping everything back off once an annoying noise starts up.
Old Sep 11, 2004 | 11:30 PM
btran's Avatar
Default Re: (lotas)
do i have to remove the rear seat and rear side panels ?
I have never done that ...and hate to break the clips on psatic panels ...
Thanks
T
Old Sep 12, 2004 | 02:01 AM
teamxtant's Avatar
I wouldn't suggest running your power wire across your engine bay to the driver side. There is a grommet to the lower left of your battery. Run you wire throught there and run in behind your kick panel and down the passenger side of your car. Remember to run your remote wire down with your power wire at the same time. Run your RCAs down the drivers side. Take out the bottom of your back seat and run your wiring under there. You will need a 16ft RCA. Last, pop the wires out under your back seat into your trunk. The lower back seat is held in by 1 10mm bolt in the center between the top and bottom half cushions. You do not have to take out your back panels.
Old Sep 12, 2004 | 08:36 AM
fcm's Avatar
fcm
Old Fart
Default Re: amp installation (teamxtant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamxtant &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't suggest running your power wire across your engine bay to the driver side. There is a grommet to the lower left of your battery. Run you wire throught there and run in behind your kick panel and down the passenger side of your car..</TD></TR></TABLE> I agree,keep the power wire as short as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamxtant &raquo;</TD></TR><TR><TD CLASS="quote"> Run your RCAs down the drivers side. .</TD></TR></TABLE>I disagree, drivers side of car is the power side, all the powers for rear of car run down drivers side;[brakes,tail,sig.,backup lights, trunk/hatch light and fuel pump power wire] run RCAs down center of car, shorter RCAs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamxtant &raquo;</TD></TR><TR><TD CLASS="quote"> The lower back seat is held in by 1 10mm bolt in the center between the top and bottom half cushions. You do not have to take out your back panels.</TD></TR></TABLE> I agree, but 10mm bolt will be 2 or 3 inchs to drivers side of center. 94
Old Sep 12, 2004 | 07:51 PM
btran's Avatar
Default Re: amp installation (fcm)
Cool ...thanks HT
I run power on driver side and remote , RCA on passenger...
Everything work out great except that i forgot to run a line for bass ajustment...
Thanks again...
T
jwm1986
Feb 5, 2010 08:07 AM
TheTealHatch
Audio / Security / Video
Aug 25, 2006 03:15 PM
Supta
Nov 16, 2004 05:59 PM
jv144
Jun 1, 2004 06:57 PM
GroundZer0 336
Aug 14, 2003 06:49 PM
