amp failure?
Old Jan 24, 2005 | 03:22 PM
93civicEX's Avatar
Default amp failure?
Hello, I've been having a problem with my sound system lately. What happens is when I turn the volume up loud, my speakers will cut out and stop playing for about a second, but my sub's will still play, This is why I think the problem is with my 4Channel amp. which is an Alpine f200, I do belive. I just installed an Infinity component system, around a month ago, But the this just started last week, Any suggestions. Thanks Joel
Old Jan 24, 2005 | 07:03 PM
civic_speed99's Avatar
Is it just the subs. You could be not be getting enough power for the volume you are playing. Possibly?
Old Jan 25, 2005 | 04:26 AM
93civicEX's Avatar
Default Re: (civic_speed99)
anyone else?
Old Jan 25, 2005 | 05:09 AM
tweekerz's Avatar
Default Re: amp failure? (93civicEX)
Check the ground.
Old Jan 25, 2005 | 06:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civicEX &raquo;</TD></TR><TR><TD CLASS="quote">Hello, I've been having a problem with my sound system lately. What happens is when I turn the volume up loud, my speakers will cut out and stop playing for about a second, but my sub's will still play, This is why I think the problem is with my 4Channel amp. which is an Alpine f200, I do belive. I just installed an Infinity component system, around a month ago, But the this just started last week, Any suggestions. Thanks Joel </TD></TR></TABLE> Check for a short on the speakers or speaker wires going to the 4ch amp, [easy way is to disconnect one speaker at a time,at the amp, testing by turning volume up, till you find the one, when diconnected, the amp does not cut out] before you try this, check the power, ground and trigger connections on the amp and the ground where its connected to the body of the car, also replace the fuses for the amp, [all fuses that are for the 4ch amp] even if they look good.
Do these "tests" one at a time, so if one of them is the problem, you will know what the problem was. 94
Old Jan 25, 2005 | 06:55 AM
tweekerz's Avatar
Default Re: amp failure? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Check for a short on the speakers or speaker wires going to the 4ch amp, [easy way is to disconnect one speaker at a time,at the amp, testing by turning volume up, till you find the one, when diconnected, the amp does not cut out] before you try this, check the power, ground and trigger connections on the amp and the ground where its connected to the body of the car, also replace the fuses for the amp, [all fuses that are for the 4ch amp] even if they look good.
Do these "tests" one at a time, so if one of them is the problem, you will know what the problem was. 94</TD></TR></TABLE>
if all that does not work, bring that amp somewhere to get tested. if it is the internal circuitry, scrap it, repair it or buy a new amp.
aznd87
Nov 5, 2006 09:54 PM
Manolo
Audio / Security / Video
Nov 11, 2005 07:21 PM
hometheaterman
12
May 23, 2005 09:32 AM
IloveNewt
10
Mar 21, 2003 10:23 AM
