Amp choices
Old Sep 1, 2012 | 07:38 AM
Fendyc718's Avatar
10 Year Member
Default Amp choices
Wanted to see what you guys think and see which is worth buying.
The alpine MRX M1000, MRX M110, or the Kenwood KAC 9105D
They would be for two alpine SWR 10D4.
Any help would be appreciated.
Old Sep 1, 2012 | 02:41 PM
edzy's Avatar
Default Re: Amp choices
Neither
Old Sep 1, 2012 | 09:04 PM
NVturbo's Avatar
O.G. triple O.G.
none of the options listed.
Find a quality OLD SCHOOL amp like a Punch 150HD, Soundstream, Zapco, etc.
Old Sep 2, 2012 | 06:43 AM
Fendyc718's Avatar
10 Year Member
Ok I'll look into those. But how come the ones listed aren't good.
And which soundstream and zapco is recommended. I don't know to much about those.
Old Sep 2, 2012 | 12:51 PM
NVturbo's Avatar
O.G. triple O.G.
The quality COMPARISON between the older amps and the new ones is like night and day. The older amps were made with better parts and the failure rate was less, yet yielding more power.
As for old school amps, here are three good examples to look for:
Soundstream "REFERENCE" amps
Zapco amps
HiFonics amps
Old Sep 2, 2012 | 01:18 PM
edzy's Avatar
Good amps
But he has 2 alpine type r's
Neither of those will supply him with 1200 @ 1ohm.
Here u go op
http://www.woofersetc.com/p-9258-sax...amplifier.aspx
Old Sep 2, 2012 | 07:06 PM
NVturbo's Avatar
O.G. triple O.G.
Those Alpine Type R amps cannot come close to those amps I mentioned. The only Alpine amps that were considered "good" is the 3500 series...such as the 3555.
Old Sep 3, 2012 | 01:01 PM
edzy's Avatar
Re-read this.
Old Sep 9, 2012 | 08:08 PM
bcook0218's Avatar
if u wanna good sub amp for them subs i would get the alpine pdx 1000.1 its a really good amp its about 1100watts at all ohm loads.. really worth the money in my eyes
Old Sep 9, 2012 | 11:21 PM
tarudude's Avatar
No complaints about the amp. My friend has this amp and it does a great job of powering his alpine type X. One thing I don't understand though..how does it produce 1100 watts at all ohm loads? That doesn't make sense.
Old Sep 10, 2012 | 03:41 AM
bcook0218's Avatar
its 1000 watt amp thats under rated just like kickers zx series and fosgates power series and a few other good brands.. the only diff is the alpine pdx is the only amp on the market that has the same watts at 2ohm and 4ohm... ohhh and i forgot it wasnt 1ohm stable :/ was kinda tired last night when i posted lol..
Old Sep 10, 2012 | 12:28 PM
edzy's Avatar
JL's do the same
That's due to the regulated power supply
Btw, pdx amps are terrible. Nothing but noise issues with those things.
Old Sep 11, 2012 | 10:47 AM
Bad_dude's Avatar
Nothing on the market is going to compare to old school amps. If you look at the amps closely, the old school amps are much heavier for the same Watt output. The heavier it is the bigger the heatsink thus it run more efficient b/c it runs cooler. Also look at the distortion level. Higher wattage does not mean better quality. What good is cranking up the volume full of distortion.
Check Ebay for some of these amps. A lot of the sellers don't know the value of the amps and they sell them real cheap. I got my MTX 4160 for $40, that thing worth at least $200. It's super clean sound heavy as heck too.
Old Sep 12, 2012 | 08:48 AM
nsxxtreme's Avatar
That's not entirely true. While I agree the older amps are better. The reason some of the newer amps are smaller is primarily because those amps are class D amps. Which are more efficient which means they put out less heat which requires less heatsink material to dissapate.
Old school amps are horribly inefficient. That is why they get so hot. That heat is wasted energy that instead of putting into the speaker your dumping into the heat sink. Which unless you like frying eggs on your amp is bad! What you trade off in efficientcy you gain in sound quality. Which IMO is the better trade off.
Old Sep 12, 2012 | 09:08 AM
Bad_dude's Avatar
Icon3 Re: Amp choices
That part I know but from the cost vs cost, it seems the class D are smaller and cooler but the distortion and noise level is so high. I have sensitive hearing and I could hear it before the music starts.
Old Sep 12, 2012 | 10:43 AM
edzy's Avatar
lol@ you being able to hear that distortion.
Noones ears are that sensitive.
Old school amps are cool for low powered setups, but newer speakers/subs are a lot less efficient then they were back in the day.
Those 100 watt "old school" amps just don't provide enough..
Old Sep 13, 2012 | 07:27 AM
Fendyc718's Avatar
10 Year Member
The subs come with a sheet to show you how to wire two subs to one amp at 2ohms. Is their a way to wire them at 1ohm. I get a little confused at that point.
Old Sep 13, 2012 | 01:34 PM
edzy's Avatar
Old Sep 13, 2012 | 06:11 PM
joeshmo's Avatar
If you are talking about noise during silence, look for ground loops/electrical noise from alt or various other circuits. Not necessarily the amps fault.
VTEC_PRODUCTION
Audio / Security / Video
41
Jan 17, 2008 12:59 PM
DancingDorito
Dec 21, 2004 11:59 AM
B16Drag
Jan 29, 2004 10:04 PM
#1civicfan
Oct 3, 2002 05:50 PM
vtec-outlaw
Jan 28, 2002 07:27 PM
