Which amp??
Old Oct 22, 2002 | 06:57 PM
akeldama's Avatar
Default Which amp??
I've already purchased 2 JL 12w3v2 subwoofers and now I'm looking for an amp. I've narrowed it down to two:
JL 500/1
JBL 600.1
Which amp is the best for the money? Is the JL worth $180 more? How does the JBL run at 2-ohms? Thanks!
Old Oct 22, 2002 | 07:04 PM
.ShawnD.'s Avatar
Default Re: Which amp?? (EJ1)
it never hurts to go with more power but for the money i would just get the 500 it should work just fine
Old Oct 22, 2002 | 07:07 PM
akeldama's Avatar
Default Re: Which amp?? (.:s h a w n D:.)
Forgot to add:
JL - $390
JBL - $190
I have heard good things about the JBL. I know it's not a top amp but it gets the job done for the money. Can anybody add anything?
Old Oct 22, 2002 | 07:20 PM
.ShawnD.'s Avatar
humm if you really dont care about quality or scheem then just get the JBL but if your trying to win shows and what not then stick with the good stuff
Old Oct 22, 2002 | 09:37 PM
RegRedTeg's Avatar
the JBLs are nice amps, the powervalve amps are being used alot now in competitoin. Is that 600.1 new or used? cuz you can get used JBL 1200.1s all day for 200-225 and those would be badass on those subs.
Old Oct 23, 2002 | 08:42 AM
gokuson's Avatar
Default Re: Which amp?? (RegRedTeg)
jbl 600.1
Old Oct 23, 2002 | 02:07 PM
akeldama's Avatar
Default Re: Which amp?? (gokuson)
If I go with the JBL which subs (D4 or D2) should I get so I can wire them into 2-ohms to get 600 watts out of the amp.
Old Oct 23, 2002 | 02:30 PM
SiClone's Avatar
I say get a JBL 1200.1 as well.... I bought mine brand new earlier this year for $245 shipped and it powering 2 12w6's nicely....
Old Oct 23, 2002 | 02:33 PM
SiClone's Avatar
Either one will be fine because the JBL BP amps are stable at both 2 and 1 ohms (same output). However, if you want to absoultely end up with 2 ohms, then get 2 D2's. JL has a ton of wiring diagrams on their site (under tutorials) to explain it better, too...
Old Oct 23, 2002 | 03:15 PM
gokuson's Avatar
Default Re: Which amp?? (SiClone)
get 2 d2. both coils on each speaker in series, and parallel the two subs.
wiring diagrams found here!
http://www.cbrstereo.com/dual_voice_...g_tutorial.htm
[Modified by gokuson, 6:16 PM 10/23/2002]
Old Oct 23, 2002 | 03:17 PM
akeldama's Avatar
Have you ever blown your subs? What are your gains at?
Old Oct 23, 2002 | 03:33 PM
RegRedTeg's Avatar
get 2 d2s? are you telling him to get 2 dual 2 ohms or the amp D2s cuz the amps would be to much power for his JLs.
Old Oct 25, 2002 | 07:47 PM
akeldama's Avatar
Isnt the JBL 1200.1 a little overpowering for the subs I want?
Old Oct 25, 2002 | 08:06 PM
SiClone's Avatar
The subs are in a small, prefab Q logic box, .88 cu ft per chamber, which ups the power handling a bit. The gains and boost are at zero and the sub level on the Alpine 7941 is at like 3, sometimes 4. The bass is very tight and can also get loud. I know that they would kick even harder in a larger sealed box, like 1-1.5 cu ft per chamber, but this set up is in my wife's SUV, so we still need space for things like shopping bags, grocery, etc..
This set up is about 8 months old and no problems at all. If you planned on pushing the subs hard all the time, then the BP1200 would eventually kill the subs. But short periods of hard play are fine...
Old Oct 25, 2002 | 08:20 PM
SiClone's Avatar
Yeah, I guess so, but I've seen a lot of people buy the BP600 and later on need more power and are stuck with taking a loss on it when they sell it. If you haven't bought the subs yet, here's what I would do:
- Get 2 D4's. Series them to get 8 ohms. Then parallel both subs for a final impedance of 4 ohms.
- Buy the BP1200 and run it at 4 ohms. You're still sending 600 watts to the subs, which is what their recommended rms handling is.
Net result here by spending just a tad bit more money, there will be less stress on the amp, it should run cooler, and you're already set in case you ever decide to get different subs that require more juice!!!
[Modified by SiClone, 11:47 PM 10/25/2002]
Old Oct 25, 2002 | 08:34 PM
akeldama's Avatar
- Get 2 v4's. Series them to get 8 ohms. Then parallel both subs for a final impedance of 4 ohms.
I think you mean D4s. If I get the D4s and the 1200.1 is there any way to wire them to a 2 or 1-ohm load to get 1200 watts out of the amp?
Old Oct 25, 2002 | 08:51 PM
SiClone's Avatar
Yes, you're right. I was typing too fast and screwed up. I fixed it though.
As to your question.... Yes, you can still get it down to 1 ohm with 2 D4's.
Parallel each sub to get 2 ohms. Then parallel both to get 1 ohm.
Again, all the info on how to do this is here: http://www.jlaudio.com/tutorials/wiring/2dvc.html
[Modified by SiClone, 11:56 PM 10/25/2002]
Old Oct 27, 2002 | 09:12 PM
Domeskilla's Avatar
JL amp... JBL plain suck! JL amp is a better built amp.. you get what you pay for.. compare the prices.. makes you wonder? JL also has 8 ga. speaker conections.. the bigger the better i say (wire size that is)..
Old Oct 28, 2002 | 05:58 AM
akeldama's Avatar
Default Re: Which amp?? (Domeskilla)
Of course JL is the better amp. I'm asking which is better for the money which would be the JBL.
Old Oct 28, 2002 | 06:20 AM
97F22B2's Avatar
I would play it safe and get the 500.1 Jl so you dont cost yourself more money down the road. My buddy ahs the 500.1 and its a monster, so you should be pretty happy.
Old Oct 28, 2002 | 10:26 AM
RegRedTeg's Avatar
Default Re: Which amp?? (97F22B2)
The JL amp is going to sound much cleaner since its not a class D amp and the JBL amp is cuz its more for SPL. The JBL amp though will hit alot harder than the JL amp. Also the JL amp has that technology of doing 500 watts at any different ohms, some might see that as a plus but I dont like it because that means even if you upgarede your electrical system you will not get any more power than 500watts everytime.
VietFoo
Audio / Security / Video
Dec 25, 2005 12:03 AM
notguilty411
15
Apr 11, 2005 06:20 PM
Mr. Choi
Apr 19, 2004 10:06 PM
ku09
12
Oct 8, 2002 06:27 PM
ShowSpeed
10
Dec 10, 2001 09:20 AM
