Alpine Type-S?
Old Dec 7, 2006 | 06:26 AM
chippy's Avatar
Default Alpine Type-S?
Is this a good choice? My stock speakers are slowly going out the Highs are barely noticable anymore.
Fronts -
Alpine Type-S 6-1/2" 2-Way Car Speakers with Polypropylene Cones
Rears-
Alpine Type-S 6" x 9" 3-Way Coaxial Car Speakers with Polypropylene Cones
This will be powered by a Alpine CDA-9827.
Old Dec 7, 2006 | 07:19 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alpine Type-S? (chippy)
Although they are pretty good speakers they need more power then your HU has to sound good, also the 6.5" are over-sized 6.5" not the standard 6.5" your Honda uses, so some mods will have to be done to fit them.
If you want a good speaker that will run off HU power, have a look at the Eclipse, or Infinity speakers, they have speakers that fit a lot easier then the Alpines
The Infinity REF6012si will fit and sound very good... http://www.infinitysystems.com/carau...er=REF&Cat=MEL
The Infinity REF9612I for the rears... http://www.infinitysystems.com/carau...er=REF&Cat=MEL although I would disable the tweeter on the 6x9s, you should not have highs comming from behind you.
The Eclipse SE8365 is also a direct fit... http://www.eclipse-web.com/integrated/se8365.html
The Eclipse SE8495 will give you massive amounts of bass for a 6x9...
http://www.eclipse-web.com/integrated/se8495.html I would disable everything except the woofer on them also. 94
Old Dec 7, 2006 | 09:29 AM
Djole_V's Avatar
wow I have the same speakers but i still did not install them in my car. I had them before in my other car they were amazing. You need a amp for them and they will sound amazing.
Old Dec 7, 2006 | 10:00 AM
chippy's Avatar
Default Re: Alpine Type-S? (Djole_V)
how big of a amp must i run? you'd think a small 250w would be enough? I'm getting this with a bestbuy discount, so pretty much what bestbuy has is what i'll be getting (selection wise)
But if they are a little harder to get in what's the necessary modifications to make them fit on the door speakers? Sorry i'm not into this section much. Usually in the turbo and fs threads more The Eclipse looks nice to i'll have to see what i can do now haha.
All the speakers you listed they will need an amp right? or no?
Modified by chippy at 7:13 PM 12/7/2006
Old Dec 7, 2006 | 11:02 AM
Djole_V's Avatar
alpine ones will need a amp so you can get all the power in them. a good 4 chanell amp would be good. try to find at least decent one?
Old Dec 7, 2006 | 12:29 PM
chippy's Avatar
okay narrowed down the amps:
-Power Acoustik 960W Bridgeable 4-Ch. MOSFET Amplifier
-Alpine V-Power 75W MOSFET Multichannel Amplifier with Adjustable Crossover
which one is better, and they both are about the same price range.
Old Dec 7, 2006 | 12:46 PM
Djole_V's Avatar
i would stick with the same brand alipne v-power is good.
Old Dec 7, 2006 | 12:51 PM
8520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chippy &raquo;</TD></TR><TR><TD CLASS="quote">okay narrowed down the amps:
which one is better, and they both are about the same price range.</TD></TR></TABLE>
The MRVF345 is a very solid amp, one I would not mind having in my own car.
Old Dec 7, 2006 | 04:33 PM
fcm's Avatar
fcm
Old Fart
Any of the speakers I mentioned will work with HU power, all of them will work better with an amp, the Alpines you want are 50W continuous to an amp that makes 50W-75W RMS into 4 ohms will work very well, the Alpine MRP-450 @4x70W RMS into 4 ohms, would work great, and a good amp also, very clean, it would also work very well with the Eclipse Point Source speakers, although a little underpowered for the 6x9s, [but that's OK as you don't want much on them anyway, and IMO the Eclipse Point Source are a better speaker then the Alpine Type S, and they fit, and the tweeter, [that you do not want in the rear anyway] is removable.
To install the Alpines you will have to make an adapter that changes the stock 5" mounting hole into a 5-39/64" mounting hole.
Mounting depth is an issue with both the Eclipse Point Source and the Alpine, for the Eclipse all you do is cut the back out of the stock speaker housing big enough for the magnet to fit through, for the Alpines use 1/2" MDF for the adapter.
In both cases, replacing the stock speaker housing wit custom MDF housings will go a long way in getting the most outof whatever speaker you pick.
BTW, the Infiniti's are a direct, [with supplied adapter] bolt in. 94
sc34dc4
Audio / Security / Video
24
Oct 11, 2011 10:36 PM
greazy_fox
Mar 21, 2009 12:16 PM
Kryptonite
Jan 13, 2004 04:31 PM
sydacheck
May 6, 2003 01:33 PM
skellator_thoj
Dec 13, 2002 06:25 PM
