which alpine speaker?
Old May 31, 2005 | 05:14 PM
Lazy Butt ALex's Avatar
Default which alpine speaker?
which one is better...the Alpine SPS-171A
http://www.etronics.com/produc...e=403
or the Alpine SPR-17LP
http://www.etronics.com/produc...d=358
the type R one is a higher brand...but the S one are compoent speakers..should i buy 2 sets (front n back) of the Compoents...
or one of each set?
or both of the type R ones...?
Old Jun 1, 2005 | 09:16 AM
strictlyimport's Avatar
Default Re: which alpine speaker? (Lazy Butt ALex)
I have the Type R components. PM me and we can talk.
Old Jun 1, 2005 | 06:07 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lazy Butt ALex &raquo;</TD></TR><TR><TD CLASS="quote">which one is better...the Alpine SPS-171A
or one of each set?
or both of the type R ones...?</TD></TR></TABLE> Use the SPS-171As up front and just the mids of a SPS-171A set for the rear, [save the tweets, in case you blow the front ones] or see if you can find a set of mids/mid bass drivers for the rear, it will be easier to set the system up if you don't have highs coming from behind you. 94
Old Jun 2, 2005 | 04:11 PM
EBP_SI's Avatar
Default Re: which alpine speaker? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Use the SPS-171As up front and just the mids of a SPS-171A set for the rear, [save the tweets, in case you blow the front ones] or see if you can find a set of mids/mid bass drivers for the rear, it will be easier to set the system up if you don't have highs coming from behind you. 94</TD></TR></TABLE>
but for the same money dont you think it would be beneficial to go with a better set of components for the front and skip the rears or at least leave them to the very end? i also dont think doing both is in the budget since its only a choise between the type S components and the type R coax's
Old Jun 3, 2005 | 06:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: which alpine speaker? (EBP_SI)
He didn't ask about better components, just about the SPS-171A and the SPR-17LP, If he had I would have mentioned MB Quart or Eclipse or JL Audio, [all of whom I think make better components then Alpine, and I would have recommended he leave the stock speakers in the rear for rear fill for now.
But he didn't, so I won't. 94
Old Jun 3, 2005 | 03:57 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">He didn't ask about better components, just about the SPS-171A and the SPR-17LP, If he had I would have mentioned MB Quart or Eclipse or JL Audio, [all of whom I think make better components then Alpine, and I would have recommended he leave the stock speakers in the rear for rear fill for now.
But he didn't, so I won't. 94</TD></TR></TABLE>
assuming he's sticking with alpine...he could at least go type R components instead of the type S in the 4 corners like you suggested. after all...your front stage is the most important part.
Old Jun 4, 2005 | 07:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
assuming he's sticking with alpine...he could at least go type R components instead of the type S in the 4 corners like you suggested. after all...your front stage is the most important part. </TD></TR></TABLE> Why not Type X ? again, it's not what he was asking 94
Old Jun 4, 2005 | 04:37 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Why not Type X ? again, it's not what he was asking 94</TD></TR></TABLE>
because the type R components like i suggested....are in the same price range as putting type-S coax in all four corners like you suggested. but hey, what do i know...i'm not an installer
Old Jun 4, 2005 | 06:35 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote"> as putting type-S coax in all four corners like you suggested. </TD></TR></TABLE>What is it EBP_SI, haven't seen you in a while, feel the need to give me a hard time again, Before you get up on that high horse of yours, I did not suggest he put Type-S coax in all 4 corners, he asked about the SPR-17LP, [a 6.5" coax speaker] and a the SPS-171A [a set of 6.5" components] I suggested.......
You know where you can stick that 94
dragon909boi
May 30, 2008 01:07 PM
Dxb_Wolf
Honda Civic (2001 - 2005)
Apr 8, 2007 02:12 PM
honda genome
Aug 26, 2006 10:12 PM
DC2_2
Audio / Security / Video
12
Jun 1, 2006 11:10 PM
{Powered by VIII}
29
Jan 17, 2006 08:36 PM
