Alpine MRD-M1005
Old Dec 24, 2005 | 09:40 PM
skrewdriver88's Avatar
Default Alpine MRD-M1005
I was wondering if the Alpine MRD-M1005 is a good amp to power my two Alpine SWR-1042D. If not what would be a good amp. Thanks guys.
Old Dec 24, 2005 | 09:58 PM
Sexcrime's Avatar
Default Re: Alpine MRD-M1005 (skrewdriver88)
I love alpine amps, the m1005 has a lot of power for 10's, but it should work great and you wont have to worry about underpowering them
Old Dec 24, 2005 | 10:07 PM
Cobb2819's Avatar
won't work. the swr-1042D is a dual 4 ohm voice coil sub, meaning, you'll either be running the amp at 4 ohms and making no power, or you'll be running it at 1 ohm and shutting the amp down by sending it into protect. if you can find them, get some SWR-1022D, those are dual 2 ohms. and will be a great match for an mrd-m1005. or...run 1042d's with an mrd-m605 on each sub. 2 subs, 2 amps
Old Dec 25, 2005 | 02:19 PM
Default Re: Alpine MRD-M1005 (Cobb2819)
Bump what other kind of amp could i get. Don't i need one that has 1000W RMS?
Old Dec 26, 2005 | 12:29 PM
ttt
Old Dec 27, 2005 | 10:36 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
JL 1000/1 is 1000watts RMS at 4ohm if that's what u need. If your subs are dual voice coil 4 ohms, then it'll wire to 4ohm mono. You need an amp that puts out about 1000watts at 4ohms.
If you wanted to use the Alpine MRD-M1005, you'd need two, dual voice coil 2ohm subs SWR-1022D's.
Just search, there's tons of amps that are rated for 1000watts@4ohms.
Old Dec 28, 2005 | 05:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: Alpine MRD-M1005 (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">JL 1000/1 is 1000watts RMS at 4ohm if that's what u need. If your subs are dual voice coil 4 ohms, then it'll wire to 4ohm mono. You need an amp that puts out about 1000watts at 4ohms.
Just search, there's tons of amps that are rated for 1000watts@4ohms.</TD></TR></TABLE> Ditto that, kind of, the JL Audio 1000/1 is 1000W rms into 1.5 to 4 ohms at 11 to 14.5 volts.
http://mobile.jlaudio.com/prod...d=221
The Alpine MRD-M1005 is only half the power you need.
Two Alpine MRD-M605s is better but still underpowered.
Get the JL amp, you will not be disappointed 94
Old Dec 28, 2005 | 05:14 PM
ScareyH22A's Avatar
Community Builder
Default Re: Alpine MRD-M1005 (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Ditto that, kind of, the JL Audio 1000/1 is 1000W rms into 1.5 to 4 ohms at 11 to 14.5 volts.
Get the JL amp, you will not be disappointed 94</TD></TR></TABLE>
If you wire up your subs to 1.5 or 2 ohm and use the JL 1000/1, the adjustments (mainly gain & boost) will get really figety. I wouldn't recommend it. But if you must try, (much like myself. I like to mess around with it no matter what other people say) then go for it. I'm sure you'll agree. My JL salesrep does and their techs do.
Old Dec 28, 2005 | 06:41 PM
fcm's Avatar
fcm
Old Fart
I would series the VCs, [8 ohm load] parallel the subs [back to 4 ohms] the JL amp will like it there. 94
Old Dec 28, 2005 | 09:07 PM
Well my girlfriend went out and bought a Rockford Forsgate Power T8002. Which yes i know is not enough power but could somebody show me how to wire it up so i will get the most out of it?
Thanks
cmwright1986
Audio / Security / Video
Dec 3, 2006 10:57 PM
N1NjA TuRtLE
Sep 25, 2006 05:21 PM
B16Drag
Jan 29, 2004 10:04 PM
ShowSpeed
10
Dec 10, 2001 09:20 AM
GoLowDrew
Jul 17, 2001 09:49 PM
