Alpine deck power cutting out sometimes?
Old Aug 7, 2004 | 01:26 PM
Poop111444's Avatar
Default Alpine deck power cutting out sometimes?
I have an Alpine CDA-7894 deck. It is wired directly to the battery.
Most of the time , it works just fine. But sometimes i may stall my car, or turn it off for a moment to fill up the gas, and it wont come back on. Everything else works, but the deck will not turn on.
10 minutes later it will just turn itself back on and work like normal. THe problem almost never happens after its been sitting say like all night and i drive off in the morning. Deck will always turn on. But after its warm, and i turn it off for a moment and turn it back on, sometimes it wont come on for like 10-15 minutes.
Deck has been running fine for about 1-1/2 years. Is this a problem with the deck or something else? Any ideas?
Old Aug 7, 2004 | 01:42 PM
skooboy's Avatar
Default Re: Alpine deck power cutting out sometimes? (Poop111444)
Sounds like there's something wrong with your deck.
But I would check the power wires again. Or test another deck.
Old Aug 7, 2004 | 01:44 PM
Eric R's Avatar
Check the ground and the other two contacts. Something might be loose or you radio has an internal problem.
Is it keeping the memory when it comes back?
Why you have the deck hooked up directly to the battery anyway?
Old Aug 7, 2004 | 01:56 PM
Poop111444's Avatar
Default Re: Alpine deck power cutting out sometimes? (Eric's R)
Alpine recommends it being hooked up directly to the battery.
I used to have a speed harness that replaced the alpine harness and the civic harness connector that I got from Circuit City (That eliminated directly connecting it to the battery).
Since the lights were somewhat dimming when the bass hits, i decided to use the factory alpine harness and wire the power to the battery.
I believe the issues started happnening after that. I only listen to XM radio, and before with the speed harness, it would remember my last channel i was on. Now with this new setup, and the power problem sometimes, it resets to channel 1, but all the sound adjustments are saved.
Old Aug 7, 2004 | 01:57 PM
Poop111444's Avatar
Also, the power wire is good and the connection to the battery is solid. I solder all my wires.
Old Aug 7, 2004 | 02:07 PM
Eric R's Avatar
Sounds like an internal problem, then.
That deck is out of factory warranty, did you purchase a extension to the warranty at the store?
You might need to service it!
Old Aug 7, 2004 | 02:54 PM
Poop111444's Avatar
hehe i didnt get an extension from Circuit because i was working there at the time. I was thinkin an internal problem. I'll be ok in the meantime unless anyone has any ideas?
Old Aug 7, 2004 | 07:31 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poop111444 &raquo;</TD></TR><TR><TD CLASS="quote">hehe i didnt get an extension from Circuit because i was working there at the time. I was thinkin an internal problem. I'll be ok in the meantime unless anyone has any ideas?</TD></TR></TABLE> Did you wire both the red and the yellow from deck to batt., or just the yellow? 94
Old Aug 7, 2004 | 08:23 PM
Poop111444's Avatar
Default Re: Alpine deck power cutting out sometimes? (fcm)
Just the yellow...... the red was probably connected to the harness? Should i cut it and connect it to the battery then?
Old Aug 8, 2004 | 03:38 AM
Xsi's Avatar
Xsi
Does the unit lose it's settings when it cuts out? if not then it's probably a problem with the acc lead.
Old Aug 8, 2004 | 07:53 AM
Poop111444's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Does the unit lose it's settings when it cuts out? if not then it's probably a problem with the acc lead. </TD></TR></TABLE>
No
Old Aug 8, 2004 | 08:12 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poop111444 &raquo;</TD></TR><TR><TD CLASS="quote">Just the yellow...... the red was probably connected to the harness? Should i cut it and connect it to the battery then?</TD></TR></TABLE>
No, leave it wired to the harness, but check the connection.
When the HU does not work, is it just that there is no sound,or is the HU off? [no lights]
Old Aug 8, 2004 | 08:27 AM
Poop111444's Avatar
HU will have no power
Old Aug 8, 2004 | 09:42 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poop111444 &raquo;</TD></TR><TR><TD CLASS="quote">HU will have no power</TD></TR></TABLE> If the problem was with yellow wire, you would lose all presets and clock in HU , if the problem is with acc.,[ red wire] HU will be off, but when it comes on again you will still have the presets and the clock, if this is so, recheck the red acc. wire, if you are sure that the acc.connections are good,[ at plug into oem plug, at connection of adpt. harness to HU harness, and at HU harness plug into HU, then problem is in the HU,[ maybe a cold solder joint] as problem is there when unit is warmed up. 94
Nastie
Dec 28, 2007 05:54 AM
tegman85
Audio / Security / Video
Jul 19, 2007 10:08 AM
riseagainst
Aug 30, 2005 05:48 PM
untitledsn41
Feb 2, 2005 10:23 PM
egizzle8
Jun 23, 2004 10:20 PM
