The be-all-end-all kill switch with a relay thread (confirmation?)
Old Jan 1, 2004 | 03:28 PM
kablamo's Avatar
Default The be-all-end-all kill switch with a relay thread (confirmation?)
Ok i've read up through many searches what i should do for a kill switch, i've decided i'd definitely rather have a relay in the system than not. however, everyone has different ways of wiring the system together! can someone confirm that what i'm doing is correct (it's on a 95 teg, but i'm guessing this applies to pretty much any honda)
-cut power wire to fuel pump (yellow)
-relay: -pin 30: power to fuel pump (yellow wire)
-pin 87: power to fuel pump (other side of cut yellow wire)
-pin 85: ground (switch is somewhere on this wire)
-pin 86: tap into power wire for fuel pump (yellow)
-pin 87a: dead lead (LED connected to ground if desired)
Is this all that is needed? i've read some threads where it is mentionned that having a diode would prevent any loss of fuel if the switch is flicked while driving (where would this diode go? i'm guessing between pin 85 and 86? but in what direction?).
Any help would be appreciated - like i said i've looked through lots of threads and some sites, but everyone seems to have overly elaborate setups (or am i missing something??)
Old Jan 1, 2004 | 03:58 PM
vteg's Avatar
New User
Default Re: The be-all-end-all kill switch with a relay thread (kablamo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kablamo &raquo;</TD></TR><TR><TD CLASS="quote">
Any help would be appreciated - like i said i've looked through lots of threads and some sites, but everyone seems to have overly elaborate setups (or am i missing something??)</TD></TR></TABLE>
For a fuel pump you want a latching setup. That way if the switch is flipped while you are driving the car does not go dead. The first example here http://www.the12volt.com/relays/page2.asp#psk is how you would set that up. Also with this setup you can use a momentary switch which is much easier to hide, plus you don't have to remember to turn it off. That example will work perfectly, just put the two ends of the fuel pume wires where the starter wires are listed.
Old Jan 1, 2004 | 06:37 PM
Auex's Avatar
Default Re: The be-all-end-all kill switch with a relay thread (vteg)
If you do this type of set up just make sure that you always carry a spare relay and the tools to change it. They will eventually fail and it will leave you stranded.
Old Jan 2, 2004 | 09:02 AM
kablamo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteg &raquo;</TD></TR><TR><TD CLASS="quote">
For a fuel pump you want a latching setup. That way if the switch is flipped while you are driving the car does not go dead. The first example here http://www.the12volt.com/relays/page2.asp#psk is how you would set that up. Also with this setup you can use a momentary switch which is much easier to hide, plus you don't have to remember to turn it off. That example will work perfectly, just put the two ends of the fuel pume wires where the starter wires are listed.</TD></TR></TABLE>
ok questions:
-what exactly is a momentary switch? a switch you push in and that's it? as opposed to a toggle switch?
-i dont understand the wiring diagram #1 (i dont have an alarm...). do these need an alarm to work (ie detect whether the alarm is armed or not?)
Old Jan 3, 2004 | 12:29 AM
vteg's Avatar
New User
This is the one I was pointing you to
You got the momentary switch right. You just push it after putting the car to the run position, then you would start the car. When you turn off the car, you would have to do it again.
Old Jan 3, 2004 | 06:41 AM
kablamo's Avatar
ok *THAT* makes sense... i was definitely looking at the wrong diagram...
one last question... which wire needs to be tapped for the ignition 12V+? is there any area where that specific wire is easier to reach? i'd check in my haynes manual ( ) but i dont want to dig through the dash anymore than i have to.
Old Jan 3, 2004 | 11:50 PM
vteg's Avatar
New User
one last question... which wire needs to be tapped for the ignition 12V+? is there any area where that specific wire is easier to reach? i'd check in my haynes manual ( ) but i dont want to dig through the dash anymore than i have to.</TD></TR></TABLE>
I think you can use any accesory or ignition wire. I would check with a voltmeter to make sure there is no power loss on the line you choose while cranking though
Old Jan 4, 2004 | 07:36 AM
toyzbus's Avatar
One suggestion I do have for you guys is to have 87a wired to a siren or a pain generator (loud high pitched siren under the dash) so that way it not only kills the fuel pump lead, but it also will set off an audio deterrent. Just make sure that the siren's does not draw more current than what the fuel pump relay is rated at.
all_motor
Feb 3, 2013 11:30 AM
beastman@
Audio / Security / Video
May 17, 2008 01:05 AM
96electronH
Dec 2, 2007 05:29 PM
1989CivicSi
Dec 28, 2005 02:04 AM
StreetRacnGsR
23
Jun 18, 2003 05:05 AM
