Alarm System is draining battery. help.
Old Feb 8, 2007 | 02:15 PM
truevietluv636's Avatar
Default Alarm System is draining battery. help.
well my car dies out if i park it over night. i hooked up an ammeter to test for battery drain. it read .25, looking at my alarm system i pulled the fuse out for the door locks and retested the battery drain again and it read .003. i have aftermarket two wire actuators and a clifford 10.5. could someone tell me what could be wrong. like could the actuators be somehow grounding out or something. (the alarm locks and unlocks like normal)
Old Feb 8, 2007 | 07:18 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Alarm System is draining battery. help. (truevietluv636)
make and model of the car.
Old Feb 8, 2007 | 09:26 PM
suspendedHatch's Avatar
If you had a relay constantly triggered it could drain the battery overnight. But out of the hundreds of cases where a customer has blamed one of our installs for battery drain, I've never had a single one that wasn't due to either a weak battery or alternator.
Old Feb 10, 2007 | 03:48 AM
JSPECSIR's Avatar
Default Re: Alarm System is draining battery. help. (suspendedHatch)
have you guys ever noticed all the battery drain customers never show up until its cold out and the batteries cant hold up. but it has nothing to do with the temp. its ALWAYS the install....
Old Feb 10, 2007 | 03:49 AM
JSPECSIR's Avatar
Default Re: Alarm System is draining battery. help. (JSPECSIR)
sorry man didnt mean to thread jack. does that fuse only run the locks, or the entire security system?
Old Feb 10, 2007 | 07:47 AM
fcm's Avatar
fcm
Old Fart
Unless there is short of some sort in the door lock system, in this case inside the alarm brain, where the built in door lock relays are, if pulling that fuse, in the common fuse holder on the violet and violet/black leads, drops the draw from .25A to .003A I would say there is a problem with the alarm brain, maybe a blow diode or resistor on the door lock circuit, [in the alarm brain].
Have you tried leaving the fuse out over night to see what happens, have you tried leaving the batt. disconnected over night to see what happens?
I would take the car to a batt./alt. shop and have them do a proper load check on the charging system, it should not cost anything it only takes a min. or so to do. 94
Old Feb 10, 2007 | 08:20 AM
thanks for the info. i did some more testing and i think its the alarm brain.
im just going to hook up a new battery and leave it in the trunk, the front battery would be connected in parallel with the trunk and have a switch to it. front battery would be for alarm and rear for car. switch would be to cut the two batteries for overnight parking and turn the switch on during driving so both batteries would charge. good idea? let me know what you think. thanks
Old Feb 10, 2007 | 12:15 PM
fcm's Avatar
fcm
Old Fart
Yes parallel, use a solenoid instead of just a switch, trigger solenoid with a true ign. and it will automatically connect/disconnect the rear batt. from the front batt. and alt.
With the above said when using 2 batt. it is always best if both batt. are the same, and new to start with. 94
Old Feb 10, 2007 | 03:16 PM
Default Re: Alarm System is draining battery. help. (fcm)
thanks, a triggered solenoid does sound better than a switch. s 4 gauge wire ok for this use? what kind of trigger solenoid should i get and where to get it? all i got are relays (the alarm ones).... i was thinking about using a relay in connection with the ignition wires and hook up the batteries in parallel like that but are the relays too small for that use?
Old Feb 10, 2007 | 03:51 PM
fcm's Avatar
fcm
Old Fart
No! do not use a relay, find an RV shop or most car parts shops will also have "Battery. Isolation Solenoids"... http://www.bcae1.com/battiso.htm
Don't forget continuous duty solenoid. 94
Old Feb 10, 2007 | 04:36 PM
thanks. how much do it cost?
Modified by truevietluv636 at 5:54 PM 2/10/2007
Old Feb 10, 2007 | 04:55 PM
why not just fix the problem
Old Feb 11, 2007 | 04:55 AM
JSPECSIR's Avatar
Default Re: Alarm System is draining battery. help. (wrx-killer-Sti eater)
aamp, metra select products, etc. all sell high current relays. we use their 80 amp relays on hiway patrol cars at my work, weve only had one go bad out of hundreds, and thats cause the terminals were overtightend. something like this could be an option. i think they have larger also.
Old Feb 12, 2007 | 08:53 AM
cant fix the problem.... the fuse is only connected to the door locks system. i used an ammeter and there was battery drain so i pulled out the door acturators and still a drain so the problem cant be the acturators, pulled out the relays and used new ones and had the same battery drain. so now cant be the relays or acturators so all i could think of is that the alarm brain is draining power somehow.
Old Feb 12, 2007 | 03:27 PM
JSPECSIR's Avatar
you should have a buddy hold the ammetter between the battery and the terminal, and you should start pulling fuses and putting them back 1 by 1 until you see the current draw drop.
Old Feb 12, 2007 | 04:30 PM
yeah, i did that and found out that the draw was comming from the alarm system's power locks on the doors. once i pull the fuse it goes from .25 to .005....
Old Feb 12, 2007 | 04:31 PM
JSPECSIR's Avatar
are they oem locks or aftermarkt? did you add relays or what?
Old Feb 13, 2007 | 09:01 AM
aftermarket with relays. i dont think they're relay problem because i swapped the relays out with some new ones and had the same readings.
Old Feb 13, 2007 | 11:07 AM
fcm's Avatar
fcm
Old Fart
Why are you using relays? The Clifford Matrix 10.5X has door lock relays built in. 94
Old Feb 14, 2007 | 06:46 AM
really? u sure? damn, i never knew that.... i'll try and pull out the relays and see if they work later today.
Old Feb 14, 2007 | 10:59 AM
fcm's Avatar
fcm
Old Fart
http://www.directeddealers.com...5.pdf page 12 of install manual. 94
Old Feb 14, 2007 | 04:55 PM
thanks for the info. removed the relays and alarm works perfectly. i'll test if there is any battery drain this weekend.
Old Feb 15, 2007 | 04:29 PM
do high current relay isolators have any battery drain? i emailed Stinger about their SR80 Relay and they said it doesnt have any battery drain. i think they're just trying to sell their crap but i want to make sure. the relays are really cheaper compared to the battery isolation solenoids so i was thinking of just getting the relays. what you guys think?
Old Feb 15, 2007 | 07:45 PM
fcm's Avatar
fcm
Old Fart
They are correct, when relay is not energized, but then neither does a solenoid, keep in mind a solenoid is just a relay that uses a slightly diff. way, [still electromagnetic] of closing it's high current switch.
As for price, if you want a REDARK 100A continuous duty, automatic solenoid, then yes you can pay $150 or more for one of them, however they can be had for as little as $15, like with relays price will go up as amperage goes up. 94
Luchini
Audio / Security / Video
Jun 16, 2010 09:00 AM
zombo
May 21, 2010 06:51 AM
Wilymakeit
Mar 11, 2008 10:23 PM
93civicsedan
Oct 10, 2006 10:52 AM
