alarm door lock problem.
Old Mar 15, 2003 | 09:05 AM
x00gsr's Avatar
Default alarm door lock problem.
When ever i start my car my dei alarm would lock my doors and whenever i turn off my car it would unlock the doors. Well, now its doing the opposite, its unlocking the door when i start the car and it stays locked after i turn off the car. I just finished my install of the remote start. what is the problem?
Old Mar 15, 2003 | 02:56 PM
koco's Avatar
Default Re: alarm door lock problem. (x00gsr)
Did you change any wiring for the door locks. Sounds like something is reversed. Perhaps the door lock relay wires. Do your door locks plug into the alarm brain or is there a relay pack external? I guess you could always reverse the polarity on your actuators <<MacGuyver fix.
Old Mar 15, 2003 | 04:47 PM
civictypenos's Avatar
what does it do when you push the button on the remote?
Old Mar 16, 2003 | 10:30 AM
x00gsr's Avatar
Default Re: alarm door lock problem. (civictypenos)
when i press lock on the remote it locks the doors and the same as when i unlock them. Its just when i start the car its not locking the doors and vica versa. It use to do that.
Old Mar 16, 2003 | 01:17 PM
it is a programable feature on most alarms,check to make sure its programed for it.
Old Mar 16, 2003 | 02:56 PM
x00gsr's Avatar
Its programmed, because i had this feature before. Some how when i installed my remote start its causing my door locks to work in reverse.
Old Mar 16, 2003 | 05:34 PM
what kinda car,what kinda alarm,does it have factory door locks.
the locks would only be hooked up one way,thers really no way it could work right with the remote and then not work right when the ignition conteolled door locks kicked in.
Old Mar 17, 2003 | 04:34 PM
x00gsr's Avatar
98 honda civic ex. DEI 790xv alarm. Trust me it works with the remote, but the ignition controlled door locks work opposite.
BrianB16A2
Dec 1, 2013 11:23 AM
94trouble
Audio / Security / Video
20
Oct 4, 2011 04:55 AM
bella_bluelude
Apr 8, 2005 08:35 AM
Hunter
Oct 27, 2002 08:02 PM
