alarm doesnt work after battery swap.
Well 3 weeks ago I was having really low idle in my 97 civic. I checked the battery and found out that it was a bad battery.
I took the battery out of my 92 hatchback si and put it in my 97. Everything worked fine, and it idled right.
Well three weeks later, i needed a battery for my 92 si to do it's initial first start up. I took the battery out of my 97 civic and put it in my 92 si for the start up.
WELL i then put the battery back into the civic. I started it up and my idle is super low like it was three weeks ago.
Also my alarm doesn't even work anymore.
What do you guys think? thanks.
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Re: alarm doesnt work after battery swap.
Bad alternator and the remote needs to be reprogrammed. It might of fell out of sync with the brain
1 Post
How did you determine the battery was bad? A bad battery wont work in a car regardless of the condition of the alternator. A bad alternator wont cause a car to idle super low either. The battery could have been drained due to a bad alternator, making the battery provide power to all the electrical components in the car. A car needs a certain amount of voltage to even kick over so if the battery was bad in your EG, it shouldn't have even started in the EK. So I think telling us how you diagnosed the battery being bad would help in determining where your problem lies.
The alarm not working could be due to what Desmon has mentioned. But once again, how did you determine the alarm is not working? Does the car lock and unlock with the remote? The remote can be re-synched with the alarm brain. If you have the manual for the alarm system or look online you should be able to find out how.
When i would crank the the car it will barely over and start. Also it's a OEM honda battery which has been used since 1997.
the viper alarm doesnt have power door locks. I would try to arm it and nothing, its silence.
Do you know were the valet button is? I betting that the alarm is out of sync with the remote. And you really need to test the alaternator. Easy way is to start the car. With the car running unplug one of the terminals off the battery. If the car dies then its the alternator. Also you should metter the output of the alternator. It should be about 14.4 volts at idle
actually i did that this morning, i had my car running and i unplugged my postive terminal, but the car did not die.
With my OEM honda Battery the voltage was 12.xx when it was idling.
I don't know where the valet button is since i bought the car and the alarm was already on it, but regardless im going to have the battery and alternator tested tomorrow
in the mean while...where are the usual spots for the valet button ?
turn the key to the on position. press valet button once and hold it. While holding the button down press the lock button on the remote. The siren should chirp once. turn the key off.
Old Fart
That would be press (and release) valet button once then press and hold it and press lock/arm button on remote, I'm pretty sure.
You will need to find the valet switch, obviously, there are no "usual" spots for a valet switch, it should be mounted under dash, hidden and within reach of the driver.
You will need to find the alarm brain to get a model number. 94
1 Post
You should be measuring 13.8-14.4 V while idling. 12.xx volts is what the battery should be registering when the engine is off.
So you mean this battery wouldn't turn your EG over, but you put it into your EK and it magically had the power to start the engine? Without recharging the battery in the first place? Kind of sketchy if you ask me.
And an 11 year old battery if properly maintained can continue to start an engine. I just barely changed out my battery which I've had since 1997. It worked fine until I let the battery go without charging too many times. It was powering my alarm while my car sat for a good period of time.
Aside all that my alarm is fixed. I guess it went out of sync. I turned the key on to the on position held the valet button and press the arm and at beeped. So its all fine and dandy. Yet my idle is still low. So its still something i have to do this week.
vtecnique69
Honda Civic (2006 - 2015)
11-07-2014 08:18 AM
SiB16A
12-22-2008 08:18 AM
b18cEK
10
11-06-2006 02:27 PM
Tyler_Durden
06-19-2003 09:55 AM
