Alarm
Old Jun 28, 2002 | 11:54 AM
TurBoXBirD16's Avatar
Default Alarm
I am having problem with this problem
don't ask for brand, i bought it when i was in HK
now, there is two wires, very strange, doesn't get what it means
ONE says: Doors (open/close), negative
Second one says: Doors, Positive
I have attached the first one to my ceiling light, it works, BUT, it only works for the passenger's door. What i mean is: the alarm will arm back if the door is not open after its unarmed. It will turn back on even i opened my driver's door, but not the passenger's door, HOW COME??
Second one, I have tried to attach it to my ceiling light, that "door arm" function i said above TOTALLY doesn't work, which means it won't arm back the car even i didn't open the doors. It doesn't matter for me without that function. BUT with this setup, the alarm just goes ON saying my door has been opened !! What does this wire do???
Please help
I know i am not explaining it very well,i need sleep ! thanks very much
Old Jun 28, 2002 | 04:24 PM
civictypenos's Avatar
Default Re: Alarm (xbird)
if you are installing it into a honda then you dont use the positive wire at all,just cut it off and tape it up,you ned to run the negative wire to both pin switchs.thats the easiest,just run it to the driver side,then run it under the back seat to the passenger side,done.
Old Jun 28, 2002 | 11:52 PM
t's Avatar
t
Just use the negative, Green/red at the pass door switch will catch all doors.
ronaldrperez
Feb 23, 2017 02:45 PM
mokylim
Jun 3, 2013 05:07 AM
eg:R
Nov 8, 2011 08:36 PM
EJ8 GSR-T
Audio / Security / Video
11
Apr 29, 2007 03:35 PM
vietjdmboi
Apr 3, 2005 10:57 AM
