Air horn question
Well you would have to purchase the air horn which would come with all the nessasary hardware such as the compressor and what not. Then the wire that activates the air horn (this wire would usually be connected to the horn trigger wire in the car or boat or what ever your installing the air horn in) would be connected to the siren output which is a posivtive. If the input to activate the air horn is negative you would use a relay to convert it. Connect the relay as follows:
85 - Ground
86 - siren output wire from alarm
87 - ground
87a - no connection
30 - negative output to air horn
You would then want to go into your programming and set your siren out put to a pulsed output as apposed to a constant output. Before you connect a relay you may also want to check to see if your siren output can be changed to a negative from programming or a jumper.
85 - Ground
87 - ground
87a - no connection
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blowbyu24 »</TD></TR><TR><TD CLASS="quote">im not sure what model the alarm is</TD></TR></TABLE> Viper has 37 alarms alarm/starters, I need a model number to be able to help, stick you head under the dash and find alarm brain, it will have model number on it.
94
94
MantisX
Audio / Security / Video
Aug 27, 2009 03:44 PM
SiYouLater
10
Apr 12, 2006 09:58 PM
hatchdrvr
Feb 25, 2003 06:28 PM
Dan GSR
15
Oct 6, 2002 01:29 PM
