Adding to stock security
Old Jun 8, 2001 | 11:55 AM
BK101's Avatar
Default Adding to stock security
Hi, got a 98 Accord EX three months ago. It has the keyless imm. security
system. I don't want to disable the system and would like to use the same
remote. What can I add for security?
I would like to add a shock sensor and siren, for all the kids that play outside that bang into my car.. an ideas...
Old Jun 8, 2001 | 04:39 PM
G's Avatar
G
Default Re: Adding to stock security (BK101)
I think as long as the shock sensor output is a ground or 12 volts, you can add it to your oem security. Are you sure it doesn't have one already? Do you have an alarm, or is it a keyless entry only? Anyway, if it is an alarm, you can wire up the shock sensor and have it trigger a relay (if it outputs 12 volts). If its output is ground, just hook it in parallel to the door switch.
Old Jun 12, 2001 | 01:52 AM
frqntflyr's Avatar
New User
if i remember correctly the stock honda security systems come with manuals u can refer 2 for opt. add ons.
Old Jun 13, 2001 | 12:55 PM
BK101's Avatar
Default Re: Adding to stock security (frqntflyr)
I couldn't find any info into the manual.
I will check again.
Old Jun 18, 2001 | 10:41 PM
mickey513's Avatar
DEI, the make of Viper&Clifford alarms have a line call "Automate", use for New Cars. They interface with you stock alarm, by adding a dual stage shock sensor, starter kill, but it stills allow you to use the factory remote.
sinister357
Feb 21, 2010 08:09 PM
~sp33~
Audio / Security / Video
Nov 5, 2009 02:15 PM
ROCsFinest
Jun 8, 2009 11:03 PM
chinoty
Sep 11, 2007 06:22 PM
RRRRRRRR
Aug 13, 2007 03:22 AM
