Adding 400pounds to my crx
Old Mar 11, 2009 | 01:32 PM
cuseikan's Avatar
Default Adding 400pounds to my crx
I'm probably going to be going against the grain with alot of people here. But I'm going to be adding close to 400pounds of audio equipment to my crx. Just wondering If i'm going to need to upgrade my coil overs and shocks. The ones on the car are fairly new, and the car rides smooth. Just seeing what you would do. It a 90crx hf, stock motor.
Old Mar 11, 2009 | 01:38 PM
Solid Motorsports's Avatar
Default Re: Adding 400pounds to my crx
Since most of that weight's going to be in the trunk (I'm assuming), you're going to want to avoid too much sag. Might be a perfect reason to get a coilover setup. You can use stiffer springs in the rear to offset the added weight and use the coilovers' height adjustment to account for any changes in ride height. What's your suspension budget? There are cheap coilovers on the market, you can use just coilover sleeves with cheapo springs and shocks which will ride like crap but will get the looks thing done, or spend $1k+ on a decent setup that will drive well too.
Old Mar 11, 2009 | 01:41 PM
jhammond_82's Avatar
Reject Papi
400lbs? man that'll slow you down drastically at the track. lol. even on the street it'll seem more sluggish.
Old Mar 11, 2009 | 01:43 PM
cuseikan's Avatar
Don't really have $1k to drop on coil overs, the most I can do is $200. I know that's probably not going to do much, what would be the best bang for my buck?
Old Mar 11, 2009 | 01:44 PM
Juice-UP's Avatar
Damn, I am just wondering What the hell you are adding in the car system wise to increase weight by up to 400lbs. DAMN!!! Must be a nasty system setup.
cuseikan's Avatar
LOL!! Sorry guys never really had track intentions for this car.
Had a buddy of mine that weighs 360 in the car and it was interesting.
Old Mar 11, 2009 | 01:48 PM
cuseikan's Avatar
Those subs 40pounds each that batt 110 pounds
and my memphis mojo.
walled. close to 200 pounds in wood alone.
Old Mar 11, 2009 | 01:56 PM
Juice-UP's Avatar
Holy HELL!!! I had to ask didn't I. That thing is f*#$in massive man. Props on the setup coming from another AUDIO HEAD!!! As for what I'd do, I would honestly end up getting another suspension setup like recommended previously. It blows to say more money is involved but overall you will get what it is you ultimately want.
Side Note: You thinking about getting rid of that L7 you got sitting in the Rex? LMAO!
Old Mar 11, 2009 | 02:00 PM
cuseikan's Avatar
I have the faintest Idea on where to start looking for suspension for weight reasons. What do you think about air shocks? It would be greatly appreciated if someone can point me in the right direction.
and yes to your last question.
Old Mar 11, 2009 | 02:08 PM
Juice-UP's Avatar
So another words you are looking more for function and looks then race right? Just to get the right information to point you in the right direction.
Old Mar 11, 2009 | 02:15 PM
cuseikan's Avatar
Yes sir more function. And trying to keep the ride as smooth as possible.
Old Mar 11, 2009 | 02:19 PM
ALLxMOTOR EG's Avatar
Vietnamese!
That is one huge system setup in a crx haha.
Old Mar 11, 2009 | 02:22 PM
cuseikan's Avatar
Thanks. Those are DC audio 18" LVL4XL's
Old Mar 11, 2009 | 02:29 PM
turboef90's Avatar
might as well throw a fat chick awhile your at it
Old Mar 11, 2009 | 02:33 PM
cuseikan's Avatar
LOL!! How did you know I liked them fat?
You following me.
Can someone point me in the right direction? Well towards suspension, not fat chicks. I can find them all on my own.
Old Mar 11, 2009 | 02:37 PM
4drEF's Avatar
Keyboard Humorist
Planning to lower it at all?
If not, you can probalby just settle for some stiffer eBay springs since you are on a budget of $200..
Spending a little more for some inexpensive eBay coilovers would give you some adjustability if it sags, but that's in the nighborhood of $500 I think.
400 isn't really all that much if you consider what the car is rated for when loaded with passangers.
As long as you and your fat chick aren't 500 each then I don't think it's all that bad.
All that $ in the stereo and nothing for the rest of the car... been there myself
After 3 thefts the stereo equipment stays in the house.
Old Mar 11, 2009 | 02:47 PM
cuseikan's Avatar
LOL!!! The fat chicks are taking the bus from now on.
Your right though, I hardly have anyone else in the car with me. And it's mainly for work, which is only 8 miles away.
Old Mar 11, 2009 | 02:53 PM
cuseikan's Avatar
I'm kinda having difficulty finding stiffer springs. What would I search for, I searched stiffer springs in ebay. And I just keep getting lowering springs.
Can someone help me out?
Old Mar 11, 2009 | 03:35 PM
crxblues's Avatar
i wouldnt daily drive that. whatare the intentions with the stereo?
Old Mar 11, 2009 | 03:46 PM
98civdx's Avatar
Master Detailer
110lb battery!!
makes me love my gay mini battery lol
Old Mar 11, 2009 | 03:48 PM
4drEF's Avatar
Keyboard Humorist
Off the top of my head, I remember Eibach and Tanabe used sell lowing springs.
A lowering spring is uses a spring that can hold up the load better due to it being lowered, but it usually comes with the side-effect of a bouncy ride since the stock shocks are still used.
Thinking a cheap set of coilovers might be the best approach since you can adust the ride hieght if the back sags. Even a set of ground control sleeves can do this for you.
garageEF's Avatar
Look in the glovebox of any crx and you will see that the maximum weight capacity is 400lbs.
This fact alone should tell you that the stock suspension is going to have a difficult time controling all this weight. I would suggest sleeve-type coilovers because they will have stiffer springs and give you some adjustability (just in case), and they can be had anywhere from $50 to $350. just remember that you get what you pay for as far as ride quality goes.
Old Mar 11, 2009 | 05:14 PM
lee0149's Avatar
i got a ? for you. Is the box air tight? minus the port if you have it. Like the place where the back shocks come up how you gonna fill that in or its going to be left like that?
for the shocks you can get some GC/koni or gc/tokico
Old Mar 11, 2009 | 05:59 PM
TunerN00b's Avatar
Since cost is an issue...
Koni Sport (Yellow) shocks. They have multiple circlip locations to reposition the spring perch. Set the rear to the higher setting (middle is stock), which would lift the rear some if the additional weight wasn't there. You only need a pair for the back. Use stock rear springs.
If that doesn't get you there (its still sagging too much), throw a set of spring rubbers in the rear springs to increase the rate slightly (really cheap), or stuff a rubber spring spacer (also dirt cheap) between the spring and upper shock mount.
That's both the cheapest and least likely to compromise ride quality solution.
That rating isn't for just the suspensions consideration, strain on the engine from pulling extra weight (reliability), strain on the brakes to stop the extra inertia, and handling are all factored in. The car will now have a good chunk of weight at the rear of the car, and relatively high from the ground. Sounds like a recipe for sudden oversteer to me.
Just something to keep in mind. Its your car and your safety, I won't preach (too much).
LsVtec08
Suspension & Brakes
Dec 10, 2010 08:04 PM
Dirty_SL8
Oct 8, 2009 05:46 PM
the jdmchop
Suspension & Brakes
22
Jun 7, 2006 04:28 AM
BeNn
10
Mar 25, 2004 07:04 PM
Mr.SpiLLz
May 12, 2003 10:20 PM
