91 hatch radio install odd problem
Old May 4, 2010 | 10:21 AM
91ef_civic's Avatar
Default 91 hatch radio install odd problem
okay i have a 91 hatch with the stock wiring for the radio. im trying to install a cheap JVC aftermarket radio in the car. i plug in the harness and wire it according to the instructions and colors. when i put the car in ACC mode all i get is the eject to work for 1 second and nothing else. when i start the car nothing works.... i dont understand it? what am i doing wrong.
Old May 5, 2010 | 08:44 AM
f22a1 ftw's Avatar
Default Re: 91 hatch radio install odd problem
just becuase there the same colour dosnt mean there the same thing on top of the stock honda radio should be a diagram of what wire does what ( atleast my 91 accord did) then just connect them accordingly btw the headunit wire harness should say what each wire does
but i hope u get it all done and also if it just shuts off make sure theres no lose wire becuase if theres one show threads it touchs metal it will just shut ur radio off
Old May 8, 2010 | 07:10 PM
fcm's Avatar
fcm
Old Fart
http://www.installdr.com/Harnesses/HA-Wiring.pdf
Make sure connections are good and insulated, [as mentioned] check the fuses, there are two of them, an ACC. fuse, usually in under dash fuse box, a constant power fuse, usually in engine bay fuse box.
There is also the possibility the "cheap JVC aftermarket radio" is DOA. 94
Jared.Mann
Feb 16, 2017 07:49 AM
kp
Mar 27, 2009 11:18 AM
dafuzzbudd
Audio / Security / Video
Nov 14, 2008 08:00 AM
the1337couch
14
Apr 27, 2007 02:20 PM
