6.5in in a integra?
Old Oct 31, 2004 | 12:09 PM
DC2 to AP2's Avatar
Default 6.5in in a integra?
i know the integra comes with stcok 5.25 front and rears. what do i need to do to put in 6.5in components up front and 6.5 coax in the rear? tia.
Old Oct 31, 2004 | 12:32 PM
EBP_SI's Avatar
Default Re: 6.5in in a integra? (xdriver)
i believe the fronts in an integra are 6.5". you may have to cut out the plastic part and make a little spacer from 3/4" MDF. dont bother with the rear speakers.
Old Oct 31, 2004 | 02:37 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdriver &raquo;</TD></TR><TR><TD CLASS="quote">i know the integra comes with stcok 5.25 front and rears. what do i need to do to put in 6.5in components up front and 6.5 coax in the rear? tia.</TD></TR></TABLE> Integras have standard 6.5" front and rear, [2doors] and 6x9s in rear of 4 doors. If the components are a standard 6.5", [and not the oversize 6.5"] then depth may be the only problem, and you can gain about an inch by cutting out the back of the speaker mounting bracket, you may need some depth reduction , you can use a spacer for that, the spacer can also be used if the speaker is a little bigger then a standard 6.5", as for the tweeter, there are lots of places in the door where they can be flushed in, keep them as close as you can to the mid. 94
Old Nov 1, 2004 | 04:29 PM
Medek's Avatar
Default Re: 6.5in in a integra? (fcm)
agreeing w/ everyone else fronts are 6.5" and pretty much any aftermarket 6.5" will require you to use a spacer, and/or modify the plastic grill set BEHIND the speakers. cutting out the the actual grill and leaving one big plastic ring did the trick for me. im running infinity 6.5 perfect components.
usdmdc2
Dec 28, 2008 01:28 AM
MSchu
Mar 25, 2008 06:43 AM
Dc2 Powered
Audio / Security / Video
12
Aug 6, 2004 06:34 AM
92TEGGSR
Jan 26, 2004 08:47 AM
vltnolia
Sep 7, 2003 09:01 PM
