welding ground wire to chassis
Old Oct 30, 2004 | 05:20 PM
bassisliffe's Avatar
Default welding ground wire to chassis
im thinking of doing this with one of those ground kits, worth it? my vehicle is really rusty so im thinking of running a wire from beside the ground for the amps to the battery as well...
Old Oct 30, 2004 | 05:47 PM
EBP_SI's Avatar
Default Re: welding ground wire to chassis (bassisliffe)
oh god...not this again.
Old Oct 30, 2004 | 06:50 PM
nsxxtreme's Avatar
LOL let me know how that works for ya!
Old Oct 30, 2004 | 07:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: welding ground wire to chassis (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">oh god...not this again.</TD></TR></TABLE> Comon EBP_SI, I was starting to miss hearing what Bass was up to. 94
Old Oct 31, 2004 | 07:56 AM
Default Re: welding ground wire to chassis (fcm)
hmm, seems no one has tried it!
Old Oct 31, 2004 | 08:31 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">hmm, seems no one has tried it! </TD></TR></TABLE>
probably because its a stupid idea
Old Oct 31, 2004 | 08:38 AM
RevToTheRedline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">probably because its a stupid idea </TD></TR></TABLE>
I agree, it's definatly something I wouldn't do.
Old Oct 31, 2004 | 11:03 AM
debogsr's Avatar
Default Re: welding ground wire to chassis (RevToTheRedline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">im thinking of doing this with one of those ground kits, worth it? my vehicle is really rusty so im thinking of running a wire from beside the ground for the amps to the battery as well...</TD></TR></TABLE>
sand the rust off homie
Old Oct 31, 2004 | 05:11 PM
Default Re: welding ground wire to chassis (debogsr)
ok
why exactly is it a bad idea?
how can i sand off rust that goes through alot of the metal
im going to try and solve my grounding issues like this
get a yellow top optima and run 0awg to a good ground point then ground the amps to the battery
hopefully that will 'ground' my issues haha bwahaha
Old Oct 31, 2004 | 05:56 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">ok
so you planned on welding the ground wire to the rust then? might be time to look for a new car
Old Oct 31, 2004 | 06:19 PM
lol, no i was going to weld it to a non rusted place, and its not that rusty really, im just too lazy to sort it out properly so ill take the easy way out, 0awg from a ground in the engine bay to a battery beside the amps and the amps grounded to the battery, ill have the box builder bbuild an enclosure just for the amps and the battery
Old Oct 31, 2004 | 07:47 PM
debogsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">lol, no i was going to weld it to a non rusted place, and its not that rusty really, im just too lazy to sort it out properly so ill take the easy way out </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">how can i sand off rust that goes through alot of the metal</TD></TR></TABLE>
The easy way out would be to sand down the metal, or ground it someplace where theres no rust. I wouldnt think welding a ground wire would be the easy way out.
Old Oct 31, 2004 | 08:01 PM
archmage's Avatar
Don't ground your amps to the Negative battery terminal, this is actually an inferior location. Use the chassis ground and keep the wire length short.
As for welding - it's not at all necessary. I'd just remove the rust the best you can (you might have to shave off some metal, maybe use a dremel with an abrasive bit) and ground at that point. If you want a permanent installation, you COULD weld it...I just don't see the point - that wire isn't going anywhere, and it should be making more than enough contact.
You could protect the ground connection with a conformal coating spray or even vaseline.
Uhh...what else
I don't like Optima batteries, but I don't feel like explaining myself. Just know that I've owned 5 of them, and most pro's in the car audio industry don't use them. I've moved on to brands such as: SVR or Hawker/Odyssey/Scosche/Lightning Audio (they are all the same battery line really, usually cheapest under Hawker or Odyssey name).
That about covers it.
Edit: Forgot to add that a good source for cheap, large gauge wire for grounding = Welding Cable! Some people actually use this for power wire. I personally use Knukonceptz.com for power/ground wire, and welding cable for grounds in the engine bay. Don't go over 4 gauge for alternator to (+) battery connection (if you redo that).
Old Nov 1, 2004 | 12:11 PM
nsxxtreme's Avatar
Here's the irony it would take just as much prep work to weld as it would to use a bolt. I would love to see someone try to weld the wire to a car LOL.
Old Nov 1, 2004 | 03:02 PM
Default Re: (nsxxtreme)
lol
ok it would be welded not wit the raw wire but on a connector
why am i not to use bigger than 4awg wire for the alt? i was going to use 0awg
ill just get to scraping, i casn use a meter and test the ground? least resistance or some crap like thary????????
Old Nov 1, 2004 | 03:28 PM
EBP_SI's Avatar
Default Re: (bassisliffe)
[QUOTE=bassisliffe]lol
QUOTE]
yeah but if youre having a problem with the ground why not just relocate it. simply welding it isnt going to solve anything and it jsut means its permanent and i dont think anything in your car is there for more that a few weeks.
Old Nov 1, 2004 | 03:30 PM
debogsr's Avatar
Default Re: (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote"> i dont think anything in your car is there for more that a few weeks.</TD></TR></TABLE>
lol
Old Nov 1, 2004 | 05:32 PM
lol!
sure i might change equipment but guess what?
all amps need a ground!
c0mbo
Honda Civic (2006 - 2015)
11
Jul 24, 2006 11:06 AM
JSTABB1
Audio / Security / Video
Jun 9, 2006 06:10 PM
JDM_Frijoles
May 18, 2006 10:17 PM
JDM_Frijoles
May 18, 2006 09:37 PM
henryicecold3000
Jun 16, 2004 12:13 PM
