2ohm or 4ohm????
Old Dec 7, 2004 | 07:04 PM
89hbcivicguy's Avatar
Default 2ohm or 4ohm????
i was wonderin guys im gettin all new **** for my car and i was really wondering if there was much of a difference between 2 ohm or 4 ohm......and if one blows easier than the other cause im starting to realize alot of the amps coming out now are for 2 ohm subs and i didnt know if i should just get a 2 ohm sub and amp to run it??????? also wondering what are sony amps like....good?.....****.....half ***?
Modified by 89hbcivicguy at 8:28 PM 12/7/2004
Old Dec 8, 2004 | 05:52 AM
PM-Performance's Avatar
Default Re: 2ohm or 4ohm???? (89hbcivicguy)
depends on your configuration. If you have a 2ohm stable amp, then run the load at 2ohms. you will get more power.
Old Dec 8, 2004 | 09:14 AM
chucksnee's Avatar
Default Re: 2ohm or 4ohm???? (itr206)
Depends on what and how many subs you are getting also, if you have a 2 ohm stable amp you can get 2, 4 ohm SVC subs and run them in series or 1, 4 ohm DVC sub and do the same. They would both equal 2 ohm load at the amp
Depends on your cash flow!!
Old Dec 8, 2004 | 11:31 AM
EBP_SI's Avatar
Default Re: 2ohm or 4ohm???? (chucksnee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chucksnee &raquo;</TD></TR><TR><TD CLASS="quote">Depends on what and how many subs you are getting also, if you have a 2 ohm stable amp you can get 2, 4 ohm SVC subs and run them in series or 1, 4 ohm DVC sub and do the same. They would both equal 2 ohm load at the amp
i think you mean parallel not series.
Old Dec 8, 2004 | 11:47 AM
Default Re: 2ohm or 4ohm???? (EBP_SI)
depends on how you look at it, if its 2 ohm subs and you can only handle a 4ohm load then you wire them in series for 4ohm. I think that what he was getting at? Maybe?
Old Dec 8, 2004 | 12:18 PM
chucksnee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
i think you mean parallel not series. </TD></TR></TABLE>
Your right had 10 things going on at once!
TANKE92113
Audio / Security / Video
12
Feb 6, 2007 01:59 PM
mrdeadman
Jan 14, 2006 04:44 PM
silentblackhat
Dec 28, 2005 11:58 AM
AznImage504
Aug 30, 2004 06:00 PM
h22accordr
Jun 6, 2004 12:02 AM
