2010 Accord Rear Defrost Trigger
Old 12-20-2009 | 08:18 AM
B18C_EJ8's Avatar
Default 2010 Accord Rear Defrost Trigger
Any ideas on alternate locations to tag rear defroster trigger other than at the radio/climate control bezel?
I'm really not interested in pulling that unit if I don't absolutely have to.
I put an Avital 4103 in my wife's 2010 Accord LX this weekend, and that's the last item left to hook up. In this car, I can't even hear the relay click when pushing the defrost button, so I couldn't trace it out that way, unfortunately.
Thoughts? Thanks!
Old 12-22-2009 | 06:16 PM
JSPECSIR's Avatar
Default Re: 2010 Accord Rear Defrost Trigger
maybe catch it at the back glass and use your own relay?
how hard was it? my wife bought an accord coupe ex-l last month. she wants some hid's and the avital 1 button remote start.
did you get a coupe? we cant see **** with the oem projectors. the foglights give off almost all the light.
Old 12-23-2009 | 04:20 AM
B18C_EJ8's Avatar
Not remotely interested in disassembling anything more than necessary. There has to be a wire going into the fuse box, and I'm sure it's neg trigger just like my '02 Accord and my Mom's '06 Civic. I just need to find it.
It was moderately difficult to install the remote start. Worst part was going into the door for lock, unlock & factory alarm disarm. At least there wasn't a molex plug in the door jamb to contend with like on earlier models.
My wife's is a 4 door LX.
Old 12-27-2009 | 06:57 AM
JSPECSIR's Avatar
straight off directechs, all the heated options.
Rear Defroster brown - latched driver dash fuse box, lt. green 33 pin plug, pin 6
Mirror Defroster orange (L), orange (R) + latched each front power window switch, gray 37 pin plug, pin 1
Left Front Heated Seat red (L), white (H) + latched driver seat heater switch, blue 6 pin plug, pins 3 and 6
Right Front Heated Seat green (L), purple (H) + latched passenger seat heater switch, white 7 pin plug, pins 4 and 7
Old 12-27-2009 | 07:50 AM
B18C_EJ8's Avatar
Outstanding! Thanks!
Wish I still had access to Directechs...
Old 12-27-2009 | 01:33 PM
JSPECSIR's Avatar
i can copy/paste the whole thing if you need it.
Old 12-28-2009 | 06:06 AM
B18C_EJ8's Avatar
Much appreciated, but the defroster trigger was the last wire to be hooked up. Everything else is working perfectly. Thanks though.
Old 01-08-2010 | 02:19 PM
nrv1's Avatar
New User
Greetings Everyone,
I followed the advice from this thread.....I tied the negative latchd pulse from the remote start to the wire specified on this thread.
The wire is on the light green connector on the driver's fuse panel....it's six pins down on the right side of the connector (BRN) if viewed from the front. When I activate the
rear defrost from the remote start, I can feel and hear the relay (located in the fuse box
under the hood) click.......so I know something is happening......but the rear defrost does not activate. The remote output is (-) latched or can be timed. The remote is a Code Alarm CA-530.
Does anyone have any ideas what can be wrong? Thanks for any help you can give.
Old 01-08-2010 | 02:30 PM
B18C_EJ8's Avatar
The output from the starter needs to be reprogrammed to latched so the defroster stays on.
Triston1228
07-01-2019 02:49 PM
KmgtypeR
11-10-2016 04:27 PM
istabrak
09-27-2005 10:48 AM
Teen Heartthrob
09-11-2003 12:28 AM
Quick Reply: 2010 Accord Rear Defrost Trigger
