Can I put this OEM CD player in my Accord?
Old 10-31-2008, 12:38 PM
swegyptian's Avatar
Default Can I put this OEM CD player in my Accord?
Hi Guys, I have some quick questions. I want to put a CD player in my girlfriends 2000 Accord LX. I want to get this unit...
http://cgi.ebay.com/ebaymotors...witem=
It says that it was pulled from an 01, does that matter that mine is one year older? Also, I want to be sure that it has green illumination. I already asked the seller, and he didn't know. If it came from an 01 Accord, is there any chance that it is orange instead?
TIA,
Alex
Old 10-31-2008, 12:50 PM
FunnyVictor86's Avatar
my 6 disc out of my 01 EX has green illumination ... yes it will fit ... as far as the illumination i wouldnt know
Old 10-31-2008, 12:57 PM
P_Adams's Avatar
Default Re: Can I put this OEM CD player in my Accord? (swegyptian)
As to the color of it's illumination, I can't comment (only because I often don't pay attention), but the players'chassis should fit without problem.
Your year accord is considered a 6th generation Accord - which spans the years 1998 up to and including 2002.
If you had asked of swapping from a 2003, THAT would have been more problamatic. Often times it's difficult swapping across Generations
P
Old 10-31-2008, 01:00 PM
NGUSPEED's Avatar
Default Re: Can I put this OEM CD player in my Accord? (P_Adams)
Yes it will fit.
The illumination however, is iffy, but those are small details, and if that doesn't matter to you, then you are golden.
Old 10-31-2008, 02:03 PM
swegyptian's Avatar
Thanks guys. Have you ever seen a 6th gen with anything other than green lights?
Old 10-31-2008, 03:37 PM
nope i haven't ... i found this one on ebay [same part no.] maybe you can contact them and ask
http://cgi.ebay.com/ebaymotors...85601
Old 10-31-2008, 05:49 PM
P_Adams's Avatar
Default Re: (swegyptian)
These guys offer LED conversion kits (soldering required) and soldering services for your year car. I have used them, and it has made a striking difference (I went Blue). Fast turn around too.
http://www.ledautomotive.com/
P
Old 11-01-2008, 10:19 AM
cb95spd's Avatar
it will fit just fine, i'm not sure if that year came equipt with a security code or not tho. you might want to ask the seller if he has the security code or do some quick research to find out if that year and model came with the sequrity feature on the radio
Old 11-01-2008, 08:41 PM
im sure that it has the security code feature ... if it does ... this thread should have everything you need to know
https://honda-tech.com/zerothread?id=2395660
feng0001
Audio / Security / Video
04-06-2006 04:15 PM
kroze
06-21-2005 05:42 PM
Johnny Gasparini
12-01-2002 08:18 PM
Quick Reply: Can I put this OEM CD player in my Accord?
