2001 Prelude MB Quart Speaker Setup HELP
Old Nov 21, 2006 | 01:56 PM
kvassassin's Avatar
Default 2001 Prelude MB Quart Speaker Setup HELP
I have a MB Quart PCE-213 and need help on connecting it from the headunit. From the MB Quart manual, it shows that one negative and one positive going to the crossover, but there are 4 wires connected to my each front stock speaker. Which are positives and which are negatives? Do I only use 1 pair (+/-) or both? If both, do I wire the two positives to one side and the negatives on the other? Here is the manualhttp://www.mbquart.com/all/dow...3.pdf If you scroll down to the bottom of the page, it has the wiring setup.
Thanx!
Modified by kvassassin at 3:21 PM 11/21/2006
Old Nov 21, 2006 | 02:18 PM
B18C_EJ8's Avatar
What kind of head unit? Any head unit should have more than 4 wires coming out...
Old Nov 21, 2006 | 02:22 PM
kvassassin's Avatar
Default Re: (B18C_EJ8)
4 wires connected to each front speaker.
Old Nov 21, 2006 | 03:00 PM
B18C_EJ8's Avatar
One pair of wires goes up to the factory tweeter.
You'll need to use the ones that don't go to the tweeter.
And just so we understand, you're not amping these components?
Old Nov 21, 2006 | 04:02 PM
kvassassin's Avatar
Not going to amp em right now, but maybe in the future. So do you know what wires I need to hook up to the crossover? So I dont need the tweeters wires right?
Thanx
Old Nov 21, 2006 | 04:09 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You'll need to use the ones that don't go to the tweeter.</TD></TR></TABLE>
Old Nov 21, 2006 | 08:59 PM
incubus's Avatar
Default Re: (kvassassin)
there isnt 4 wires coming from each speaker. I am assuming u just looked at the tweeter, a wire runs from the tweeter (splitting off the signal) to the woofer when u pull the mid out there will only be two wires connected to the back.
Also you <U>REALLY</U> need an amp, I wouldnt even bother putting premiums in without one. you will be giving them between 10-25 wrms when they want like 200-250wrms. Not only will they be quiet as hell off of a radio but you could also blow them from the massive ammounts of distortion the radio will feed them.
Quarts LOVE power! I have a QSD 3 way component set with 100wrms running to the 1" 100 to the 4" and 200wrms running to the 6.5"
Old Nov 22, 2006 | 07:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: 2001 Prelude MB Quart Speaker Setup HELP (kvassassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">Also you <U>REALLY</U> need an amp, I wouldnt even bother putting premiums in without one. you will be giving them between 10-25 wrms when they want like 200-250wrms. Not only will they be quiet as hell off of a radio but you could also blow them from the massive ammounts of distortion the radio will feed them.
Quarts LOVE power!</TD></TR></TABLE> Ditto that, get an amp and run 16ga speaker wire into the doors, otherwise your just wasting the MB's, and as mentioned, at the best ,they will sound like crap, at the worst, you will damage them trying to drive them with just HU power. 94
Old Nov 22, 2006 | 07:58 AM
kvassassin's Avatar
Default Re: 2001 Prelude MB Quart Speaker Setup HELP (fcm)
Any recommendation on amp? How about Alpine MRP-F450 or Infinity Reference 7541a ?
Thanx
Old Nov 22, 2006 | 03:12 PM
incubus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kvassassin &raquo;</TD></TR><TR><TD CLASS="quote">Any recommendation on amp? How about Alpine MRP-F450 or Infinity Reference 7541a ?
Thanx</TD></TR></TABLE>
Either will work, I would go with the Alpine first although it is lower power, I have had infinity amps in the past and never been impressed with them.
Also look at the rockford p450.4 Its a great amp for the $$.
If you are going to follow FCMs advise, which isnt bad advise, I would run two sets of thicker gauge wires into your door. The only reason I dont completely agree is that BB6 preludes have Molex plug wiring running into the doors (laments terms there is a wire harness on each side of the door so running wires is a bitch!)
By running two sets thru the doors you can bi-amp the PCEs and it will sound better, this way the tweeter and woofer arent fighting over power.
Old Nov 22, 2006 | 04:04 PM
kvassassin's Avatar
Default Re: 2001 Prelude MB Quart Speaker Setup HELP (incubus)
For around 200-300 for an amp (4channel), what would you recommending getting?
Old Nov 22, 2006 | 09:55 PM
fcm's Avatar
fcm
Old Fart
Although, would not recommend buying from anyone but an authorized dealer, and you really don't need more then 45-50 watts RMS per channel, this is a great amp... http://cgi.ebay.com/JL-AUDIO-3...wItem 94
myek96
Audio / Security / Video
12
Mar 13, 2007 02:01 PM
dafuzzbudd
18
Nov 30, 2006 09:15 AM
Mr_EmO
May 17, 2005 06:02 PM
Odessa
15
Jul 8, 2004 09:14 PM
