2 ohm or 4 ohm
Old Jul 15, 2005 | 12:22 PM
EMJAY's Avatar
Default 2 ohm or 4 ohm
more power or what? looking at some alpines for my new sound system setup. currently running 2 channel amp
Edit: the subs are type-s and my current amp is the JL 300/2. i was using 1 w7 now i'm switch to two type-s
Modified by kb12 at 4:11 PM 7/15/2005
Old Jul 15, 2005 | 02:38 PM
spyz34's Avatar
Default Re: 2 ohm or 4 ohm (kb12)
alpine what, subs? Also what is your amplifier rated at? If you buy a DVC 4ohm then you have the option for either 2 or 4. need some omre details for what you have and what you want.
Old Jul 15, 2005 | 09:13 PM
harlen's Avatar
Default Re: 2 ohm or 4 ohm (spyz34)
switch from w7 to type s?
Old Jul 16, 2005 | 07:56 AM
EMJAY's Avatar
Default Re: 2 ohm or 4 ohm (harlen)
yes my w7 ripped when my screw driver slipped and ripped the beast
Old Jul 16, 2005 | 10:48 AM
nsxxtreme's Avatar
I believe those parts are replaceable on the W7. Someone correct me if I'm wrong.
Old Jul 16, 2005 | 11:04 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 &raquo;</TD></TR><TR><TD CLASS="quote">more power or what? looking at some alpines for my new sound system setup. currently running 2 channel amp
Modified by kb12 at 4:11 PM 7/15/2005</TD></TR></TABLE> The RMS power handling on the Alpine type S subs is 300watts each, the JL amp you have is 150watts RMS x 2 into 1.5-4 ohms, [stereo] it is not stable below 3 ohms when bridged, so you have an amp that will give you about 300watts RMS mono into 3-8 ohms, although it would work, it really is not enough to run two 300 watt subs. 94
Old Jul 16, 2005 | 11:54 AM
EMJAY's Avatar
it could run the subs but i wont be pushing the subs to peak...thanks fcm i will probably look into a new amp.
Old Jul 16, 2005 | 12:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: 2 ohm or 4 ohm (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">I believe those parts are replaceable on the W7. Someone correct me if I'm wrong.</TD></TR></TABLE> I have never sent a JL speaker that was not warranty to JL, under warranty they just send you a new speaker. I have had more then one JL sub re-coned, we have a shop down in Vancouver that will re-cone any speaker, and do a very good job, and unless the re-coning kit from JL is diff. then the original, they are using generic ones, but they work well 94
Old Jul 16, 2005 | 03:29 PM
nsxxtreme's Avatar
Default Re: 2 ohm or 4 ohm (fcm)
I thought you might be able to order replacement parts directly from JL. Some of the high excursion woofers like kicker I believe, will sell the cones and surround. Then end user is able to replace these parts by themselves. I think kicker calls it "SPAIR" which is just the surround, cone, and spider in one replaceable piece.
Old Jul 17, 2005 | 07:20 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">I thought you might be able to order replacement parts directly from JL. Some of the high excursion woofers like kicker I believe, will sell the cones and surround. Then end user is able to replace these parts by themselves. I think kicker calls it "SPAIR" which is just the surround, cone, and spider in one replaceable piece.</TD></TR></TABLE>You may be right, I have never tried to order a re-coning kit from them, I have gotten kits from Alpine, Kicker, JBL, Orion and generic kits from the shop in Vancouver, all the kits have come with the cone, surround, spider and VC/VC former in one piece, a dust cap, an alignment "tool" and a tube of glue. Anybody with a little patients can re-cone a speaker. 94
Old Jul 19, 2005 | 02:15 PM
incubus's Avatar
a 300/2 isnt enough to run a w7 in the first place.
Old Jul 19, 2005 | 08:34 PM
EMJAY's Avatar
well i didnt even get to see it so....but im kinda of glad i didnt cuz that might have been to loud for the thieves once i got a new amp to handle that power. plus that 50 lb beast was a hassle for reals but i got a new setup once i get the money
dseriesboulder
Audio / Security / Video
11
Mar 14, 2013 07:01 PM
Luchini
25
Jan 24, 2006 01:32 PM
CivHatchH22
Apr 12, 2004 09:21 AM
Fuster_Cluck
Aug 8, 2003 05:57 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
