2 Alpine 12'' Type-R's
Old Sep 23, 2005 | 04:11 PM
MilanoRedDC5's Avatar
Default 2 Alpine 12'' Type-R's
Hey, sorry for a noob question, but do you guys know what kind of amp I need if I have 2 12'' Type-R's? Thanks in advance...
Old Sep 23, 2005 | 08:41 PM
C'mon...I know some of you guys out there are audiophiles. Obviously im not. Lol And I need help...
Old Sep 24, 2005 | 10:30 AM
romoracing's Avatar
Default Re: (MilanoRedDC5)
look into the alpine v12 amp.
Old Sep 24, 2005 | 12:37 PM
damn, those are expensive bro...Thanks for the input...
Old Sep 24, 2005 | 12:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: 2 Alpine 12'' Type-R's (MilanoRedDC5)
You didn't say what 12" type Rs you have, but all but the 15" are 500W RMS and 1500W peak You should be looking at a 1000W RMS mono block sub amp, you didn't give us a budget so here is one that would work real good http://mobile.jlaudio.com/prod...d=221 and here are a bunch of cheaper ones http://search.ebay.com/search/...earch 94
Old Sep 24, 2005 | 02:17 PM
Thanks...Sorry, forgot to give budget. But whatever works good im in for it...
Old Sep 24, 2005 | 09:35 PM
jonnyb123's Avatar
honestly man the way it sounds best iz if u keep the cd player amp and subs the same brand. so try to get all alpine **** and a high amperage 2 channel amp for your subs.
Good Luck
Old Sep 25, 2005 | 08:06 AM
fcm's Avatar
fcm
Old Fart
Default Re: (jonnyb123)
Unfortunately Alpine does not have a 2ch amp that will work, not enough power, and non of Alpines 2/4/5 ch amps are stable @ 2ohms when bridged, the only amp Alpine has that will work, [and it is the best Alpine for the job] is the MRD-M1005, 1000W at 14.4V into 2ohms. MSRP $600 USF 94
Old Sep 25, 2005 | 09:12 AM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately Alpine does not have a 2ch amp that will work, not enough power, and non of Alpines 2/4/5 ch amps are stable @ 2ohms when bridged, the only amp Alpine has that will work, [and it is the best Alpine for the job] is the MRD-M1005, 1000W at 14.4V into 2ohms. MSRP $600 USF 94 </TD></TR></TABLE>
Wow...I guess if it works im gonna have to go with it. But wouldn't it sound better or the same if I go with a JL amp? or any other amp that would work? Thanks again...
Old Sep 25, 2005 | 10:35 AM
SAG3's Avatar
you dont need to keep it all the same brand. if your subs are dual 4 ohm voice coils you can wire them all up in parallel for a 1 ohm load and connect it to this amp http://cgi.ebay.com/ORION-1200...wItem they will both get 600 watts.
Old Sep 25, 2005 | 11:17 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRedDC5 &raquo;</TD></TR><TR><TD CLASS="quote">
Wow...I guess if it works im gonna have to go with it. But wouldn't it sound better or the same if I go with a JL amp? or any other amp that would work? Thanks again...</TD></TR></TABLE>You do not have to go with an Alpine amp, in fact I think the JL would be a better amp, the JL Audio 1000/1 mono block sub amp is 1000W @ 11V to 14.5V into 1.5ohms to 4ohms, it is a very good sub amp.
That said, there are other amps out there that will do the job, with sub bass you don't need to put as much emphases on how "clean" the amp is as you would with a high-pass amp.
Now with that said, you will always be better off with a good brand name amp, there is nothing that can replace quality. 94
Old Sep 25, 2005 | 01:31 PM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">You do not have to go with an Alpine amp, in fact I think the JL would be a better amp, the JL Audio 1000/1 mono block sub amp is 1000W @ 11V to 14.5V into 1.5ohms to 4ohms, it is a very good sub amp.
Now with that said, you will always be better off with a good brand name amp, there is nothing that can replace quality. 94</TD></TR></TABLE>
Sounds good to me! Thanks guys...
MASTERJDM
Audio / Security / Video
Mar 14, 2007 10:24 PM
shangahman
Apr 21, 2006 10:06 AM
Hehehe I just
16
Feb 3, 2004 08:25 PM
shorty0o29
Mar 26, 2003 12:56 AM
