16 Gauge Wire?
Old Nov 6, 2003 | 04:38 PM
Boosted-Ek's Avatar
Default 16 Gauge Wire?
I have an amp that runs about 700 watts. I am running 3 12's off of it. The guy at the stereo shop said 16 gauge speaker wire was good enough. Is this right? It just sounded too small to me. Any help would be appreiciated.
Old Nov 6, 2003 | 05:39 PM
vteg's Avatar
New User
Default Re: 16 Gauge Wire? (Downs)
For what wire? To the speakers, power ground...
I would only use 16 gauge for a remote lead personally. 12 gauge for the subs. I would use 4 gauge for power and ground if that is 700 watts rms.
Old Nov 6, 2003 | 05:47 PM
rjr162's Avatar
Default Re: 16 Gauge Wire? (vteg)
16 guage would work fine. Infact, alot of Audiophiles (the ones who set their home receivers and other related equipment on air bladders so the "vibrations" don't interfer with their quest for perfect sound) believe you should use the smallest cable possible (within reason) to help keep the bass and treble signals together. Rather odd people though, if you ask me....
Old Nov 6, 2003 | 05:50 PM
queez's Avatar
Default Re: 16 Gauge Wire? (rjr162)
def too small for subs.. imagine pissing through a straw.. thats what its like... if you **** through a pvc pipe you'll get more flow.. so use something like 12 ga or even 10.
Boosted-Ek's Avatar
Yeah for the subs
Old Nov 6, 2003 | 07:39 PM
EBP_SI's Avatar
Actually from what i've seen most audiophiles use cables with miltiple wires inside of varying diameters to achieve the ideal sound. For example my audioquest speaker wires have 12 wires total, 6 for each side. all of them are different sizes.
Old Nov 6, 2003 | 07:54 PM
vteg's Avatar
New User
Default Re: 16 Gauge Wire? (queez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by queez &raquo;</TD></TR><TR><TD CLASS="quote">.. imagine pissing through a straw.. thats what its like... if you **** through a pvc pipe you'll get more flow.. .</TD></TR></TABLE>
The straw would overflow and it would be very messy
Old Nov 6, 2003 | 09:21 PM
GSteg's Avatar
16 guage would be fine. we're dealing with AC currents here, not DC. i had a 16 gauge on my e15k (had about 800 watts to the sub) and switched it to 12 gauge. no difference there..
and if your amp and subs are in the trunk, then you'll be ok. i mean..the wire is gonna be less than 5 feet if the amp is mounted near the subs..unless..u have 500 feet in your trunk for the fun of it. heh
tempsohc
Audio / Security / Video
Jul 31, 2013 09:30 PM
jaebekae
Jan 11, 2010 12:59 PM
iinvazionii
Apr 11, 2007 08:56 PM
JoshuaVTEC
Jan 23, 2006 09:33 AM
BlackAckeR
Jan 19, 2002 08:27 PM
