12V conversion HELP!
Old Nov 5, 2004 | 05:00 PM
Eskay@JDMCircle.com's Avatar
Default 12V conversion HELP!
Hi, I had a question if you guys could help, I want to convert the cars 12V source to 5 or 6Vs to power a small DC motor. What size resistor should i use? (OHMS)
Thanks
Old Nov 5, 2004 | 06:19 PM
rjr162's Avatar
Default Re: 12V conversion HELP! (skt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skt &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I had a question if you guys could help, I want to convert the cars 12V source to 5 or 6Vs to power a small DC motor. What size resistor should i use? (OHMS)
Thanks </TD></TR></TABLE>
That would depend on how much power the motor draws, also remember with the ignition off the voltage will be around 12, with it on it will be around 14.4
You might want to look around and see if you can't find a 5 or 6 volt voltage regulator, this way it won't matter if the voltage is 12 or 14.4, the regulator will "bleed off the extra".
Old Nov 6, 2004 | 12:26 AM
What kind of regular would I get? Also are those cheap as resistors (99cents)
something like this?
http://www.radioshack.com/prod...-1770
Old Nov 6, 2004 | 07:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: (skt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skt &raquo;</TD></TR><TR><TD CLASS="quote">What kind of regular would I get? Also are those cheap as resistors (99cents)
http://www.radioshack.com/prod...-1770</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">
You might want to look around and see if you can't find a 5 or 6 volt voltage regulator, this way it won't matter if the voltage is 12 or 14.4, the regulator will "bleed off the extra".</TD></TR></TABLE>
A voltage regulator will cost more then $.99 $5 for a cheep one, you need more then just a resistor, take the motor to a elec. supply store like Radio Shack, tell them what you want to do, they will tell you what you need to do it. 94
Old Nov 6, 2004 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: (fcm)
PS why not use a 12v motor? 94
Old Nov 6, 2004 | 10:15 AM
The motor is 12V, Its spinning ot fast for me, I want to slow it down with a 5V source of power now..
Old Nov 7, 2004 | 11:13 AM
fcm's Avatar
fcm
Old Fart
Default Re: (skt)
T think you can do that with a dimmer control. 94
Old Nov 7, 2004 | 12:49 PM
nsxxtreme's Avatar
Do not use a resistor. If you do the voltage will change depending on the load.
If you want to be able to adjust the voltage use an adjustable voltage regulator. It would also be wise to figure out your worst case load this will help you determine if you need a heatsink.
Modified by nsxxtreme at 2:04 PM 11/7/2004
Old Nov 7, 2004 | 03:12 PM
hmm, So I should use a voltage regulator, the Small 12V DC motor uses the car's battery which is about 14 when the car is up and running and way to much for that little motor! I need about 4-6V's going through it. The little motor probably has 1 or 2 watts going through it. Its like an RC car motor.
Old Nov 7, 2004 | 08:25 PM
nsxxtreme's Avatar
Default Re: (skt)
Use a set off batteries to add up to 4 volts. Then use a DMM so you can measure the current it is using while it is connected to whatever it is that you are using it for. You can use an adjustable voltage regulator to obtain any voltage you want.
Old Nov 7, 2004 | 09:15 PM
Ok, I got some ratings off the small 12V DC motor im using:
Gearhead Motor
60 RPM, 12VDC @ 110mA
This spins to fats when I plug it straight up to my cars 12V power supply. I want it to spin slower, I tried hooking it up to a 6V battery and it did spin incredibily slow, which is what I wanted. So how would I get this motor to spin to the speed of 4 or 5Vs?
Old Nov 8, 2004 | 04:44 AM
nsxxtreme's Avatar
Default Re: (skt)
Use an adjustable voltage regulator if you want to be able to adjust the speed at which the motor turns. If not just buy a 5 volt regulator and be done with it. Both parts can be purchased at radio shack. If you download the datasheet it will tell you how it needs to be connected
The purpose of measuring current is just to determine if you will need a heat sink.
Good luck
NICOYA
Sep 3, 2013 06:57 AM
duneracer69
Jul 26, 2008 08:38 AM
audioroach
Audio / Security / Video
10
May 4, 2005 01:53 PM
TEAMNYC
Sep 6, 2004 10:09 AM
PearlWhiteAccord
Jan 22, 2004 06:43 PM
