05 accord amp?
Old Nov 3, 2005 | 04:56 PM
93vtec ATL's Avatar
Default 05 accord amp?
does the factory 120-watt six disc system use an external amp? if so, are there adaptors to get line-level outputs without using the head units internal amp?
Old Nov 4, 2005 | 06:06 AM
B18C_EJ8's Avatar
Default Re: 05 accord amp? (93vtec ATL)
Don't know if there's an external amp, but you can get a line-out converter to tap into the speaker wires to get you RCAs to run to an amp. Available at any stereo store.
Old Nov 4, 2005 | 11:33 AM
93vtec ATL's Avatar
Default Re: 05 accord amp? (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Don't know if there's an external amp, but you can get a line-out converter to tap into the speaker wires to get you RCAs to run to an amp. Available at any stereo store.</TD></TR></TABLE>
Right.. I was hoping for the external amp, so I could bypass the noise that will be generated in the high-voltage lines cause be the internal amp.
Old Nov 4, 2005 | 11:36 AM
B18C_EJ8's Avatar
If you're running subs, noise really won't be too much of a concern... Most likely you won't even hear it.
I think you'll be fine with a converter.
chillerice
Audio / Security / Video
Oct 1, 2012 09:44 AM
b16sellout
Jan 2, 2005 05:20 PM
AznImage504
Aug 30, 2004 06:00 PM
shyboy817
Aug 12, 2004 11:30 PM
technine
15
Jun 15, 2004 08:04 AM
