-= AMBER Illumination Kit for an ALPINE Stereo =-
Old 01-13-2004, 10:38 AM
type-r 01 886's Avatar
Default -= AMBER Illumination Kit for an ALPINE Stereo =-
I have a ITR so I want to make my alpine "Green" keys to illuminate "Amber" like
the image below. Does anybody know if its possible to modify the leds inside or
if there is some kit to do this?
Here is the stereo I just bought.
Thanx in advance if you all know anything. Im sure there are others who would also like to do this.
Old 01-13-2004, 10:50 AM
jeffrey's Avatar
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (type-r 01 886)
i had an alpine head unit that chnages color from green to amber, it's factory with the stereo.. for the life of me, i can't remember the model number.
Old 01-13-2004, 10:56 AM
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (jeffrey)
Exactly, I know there is one available and I wasnt about to pay $400 more dollars for it just to have amber capabilities But I wonder if there is someway to modfy the "green" ones
Old 01-13-2004, 11:04 AM
ALF
ALF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffrey &raquo;</TD></TR><TR><TD CLASS="quote">i had an alpine head unit that chnages color from green to amber, it's factory with the stereo.. for the life of me, i can't remember the model number. </TD></TR></TABLE>
I had the CDA-7876 and that changed colors...green or amber.
I think you can still find them floating around eBay every now and then.
Old 01-13-2004, 12:00 PM
type r 01-1063's Avatar
Alpine CDA-7894
Old 01-13-2004, 01:04 PM
hungsteR's Avatar
What model Alpine do you have? I have the 7894 and it changes colors you might want to check your owner's manual.
Old 01-13-2004, 01:43 PM
New User
rcurley55's Avatar
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (hungsteR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR &raquo;</TD></TR><TR><TD CLASS="quote">What model Alpine do you have? </TD></TR></TABLE>
The picture is right there?!?! 9811
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I have the 7894 and it changes colors you might want to check your owner's manual.</TD></TR></TABLE>
I took a brief look at your owner's manual online. It doesn't appear that the illumination is switchable.
I think you have two options:
1. take it apart, and swap out the LED's that light up the buttons. I'm not sure how (if at all) tinted the buttons are. If they are tinted a strong green, this may not work.
2. buy new buttons from http://www.pacparts.com - they may/may not offer just the buttons, and you may have to buy a face with the color buttons you want....
I would try the led thing first, but be careful and make sure you have the proper leds to make this work. I personally have no clue how to do this, but if you are good with a soldering iron it shouldn't be that hard...
Old 01-13-2004, 03:07 PM
Founding Member
Mike M's Avatar
It all depends on how the faceplate is lit up, as far as the Buttons go its either LED's or small Bulbs. Most newer radios use LED's where as some older radios used to have small bulbs and you could pull the plastic covers off the bulbs and replace them with a different color. LED's are a whol other matter, they are not your normal LED at radioshack they are the very small surface mount LED's like inside a Cell Phone. From what I hear NOT easy to solder or desolder them, although I haven't tried it yet. The Display looks like you could use a Color filter in behind the plastic to change the color closer to orange.
I'm thinking of trying to convert my Ecplipse CD8051 to Red colored Display to go into my Audi, it uses those Surface mounted LED's I still have to seach online for a site selling those LED's but if all else fails I could buy one of those cheesy Cell phone covers or batteries that uses those LED's and swap them into the Head Unit. I still have to try to get a Tech sheet from Eclipse to make sure of the Voltage of the LED etc. I also have to find a color filter for the Display (I could live with a Blue display but Red Buttons) After all of that some of the buttons on my unit might not even light up red but might have a purplish red color to it as the plastic has some blue in it.
All in all it is NOT an easy job and Not one to try if you have never worked with electronics. You have to be Crazy to even try
Old 01-13-2004, 07:21 PM
HiRevn's Avatar
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (Mike M)
The old 7894 had dual illumination. If you could open it up, I don't think the color of the buttons will be a problem since the 7894 had green buttons, but didn't look green when switched to amber, although the display doesn't change colors, just the buttons.
Old 01-14-2004, 10:57 AM
If I cannot find the type of Buttons im looking for. What kind of "spray paint" can I use to paint the buttons. I seriouly will paint them like black or charcole grey.
LOL its just that I dont have once green thing in my car. IT will totally throw shat off. haha
Modified by type-r 01 886 at 8:34 PM 1/14/2004
Old 01-14-2004, 10:29 PM
dc24me's Avatar
When I took my 2002 CDA7892 apart I got off my roommate in exchange for his cut of a years Direct tv to clean up all the soda off the faceplate, the bottom buttons (1,2,3,4,5,6,f) had leds with little green condom like thingies on them that were removable.
Old 01-15-2004, 09:54 AM
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (dc24me)
LOL AWESOME! so I may be able to remove the green! Sweet.
Old 01-15-2004, 05:31 PM
teknics1's Avatar
I have an Alpine cd in my car now, not sure what model but its old. Have you tried holding in the display button? On mine, if you do that it will change the color. I see a display button in the upper left of the ppicture you have, it might be worth it to try it if you haven't yet.
Old 01-15-2004, 07:34 PM
vtec_yosh's Avatar
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (teknics1)
Yeah, the CDA7894 was awesome, I had one for a long time. We've done this before, and changed from green to blue. All we did was open the face, and the LEDs where just covered with small, rubber "condom" type things. A guy at work knew a place to get different colors, he did, we put them on, and magically, it was blue lights! Unfortunately, I do not know where he got these, but Il'l ask and let you know!
Old 01-15-2004, 08:14 PM
dc24me's Avatar
Default Re: -= AMBER Illumination Kit for an ALPINE Stereo =- (vtec_yosh)
If you have the money for a new deck and you can wait, just a few months until the new cda9835 comes out. it's still mostyly black, is a swingface sorta replacing the cda9815, but it has a biolite display. And you can choose from 4 different colors on the buttons/illunination and tune it to 512 different shades.
BB6-213
Audio / Security / Video
29
11-17-2004 10:25 AM
type-r 01 886
01-13-2004 05:02 PM
ECKOTYPER
01-13-2004 04:24 AM
Myh4tch
12-15-2003 02:11 PM
aira
10
07-30-2002 10:28 AM
Quick Reply: -= AMBER Illumination Kit for an ALPINE Stereo =-
